Learning to drive a manual again...
It must be 30+ years since I've owned a manual. But...it's like riding a bike for me. However...is it just me or is 1st gear difficult? No issues driving the car in any gear, but I must say that I must focus and be on my game in 1st gear. No feathering allowed, it's either on or off so it seems.
I'm getting better with it, but that first gear has been a little learning curve for me! Feel like a darn rookie!
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I just picked up my asp C7 this past weekend and am in the exact same boat with 1st gear. Maybe the clutch just needs to be broken in a bit. I'll admit I'm new to manual and probably suck right now but all other gears are fairly reasonable. Still in the choking under pressure stage / stalling when it counts so I'm staying off main roads for now. When I'm on a side road with no one around you can actually get the car moving with just clutch (no gas) but it's a real slow/gradual process. Not to be used at quick traffic lights
frumnuttin....I'll try that - good suggestion!
JPK - I hear ya...me too for now. Plus I live in Colorado with the hills...so even more pressure to 'perform'!
This afternoon I drove a friends Porsche and no issues with 1st gear, just like it was 30 years ago. Something different in this C7, thats for sure. For me at least! I'll get the hang of it in time, however at a stop light on a steep hill...and I start to freak out just a little.
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
On a hill you can try putting on the electric brake and when you engage the clutch it releases automatically.
I also learned to use the Hill Start Assist (HSA) to my advantage rather than try to get around it.
The clutch needs to break in, after a few miles the grabbing seems to go away, or I got use to it. Hill hold is automatic, the car senses the angle and applies the brake accordingly. Don't totally count on it, a very slight grade will not activate hill hold and the car will drift back. It is a learning curve.
My car seemed to have a smooth clutch right from delivery at the dealers. The C6 that I traded in was also manual and it seems the C7 is easier and smoother. (The car had 4 miles when I picked it up.) Within a block of the dealer I had to stop at a traffic light on a steep grade with some nut right on my tail. All I could think was "this is a great way to start!" I readied myself for the light change, prepared for some quick heel and to work. When the light changed I released the brake and the car sat there waiting nicely for me to do my thing. It never budged and in a second I was gone! I had totally forgotten about the HSA feature. It might have literally saved my ****. I should add that in have never found HSA intrusive and it takes a pretty good grade for it to activate.
Also, if you THINK about shifting, you may screw up...but if you are not paying attention, you don't!
I agree, starting from a stop in 1st gear seems to be my hardest thing too since I last drove a manual in the early eighties. Starting in 2nd gear seems more normal if you don't mine Sunday driving. I'll have to see if frumnuttin suggestion of moving the seat up, makes a difference.
Received 1,974 Likes
I did not adopt this but at spring mountain they teach you to lift the clutch w/o applying any gas......... once the clutch is out then you apply the gas. works in a pit track enviorment but probably not so much on hills.
Point is there is enough torque at idle that you don't need the gas ....just a smooth release.
I drove my 2004Z06 for 10 years, but every clutch has a different feel. I found that, as mentioned, if you let the clutch out with no throttle to the engagement point, then give it throttle, it seems to engage much smoother. You may kill it a few times until you get used to it no matter how long you have driven a standard.
Worst thing for me is when I switch between the C5 and C7.
There is a big difference between the clutch friction point, shifter location, and throw.
Was in the C5 last week, tried to shift 3-4, and missed the stick ... nothing but air.
Had to laugh.
Had to laugh.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
My wife's C5ZO6 has an MGW shifter. It's downright ugly when I change between her car and my C7
Had to get used to this car at which point in releasing the clutch. Told the salesman to use the oh **** bar as necessary and cut me some slack if I stalled as we went to get gas to give me a break as I am not used to the clutch and have to learn the points etc... I was just hoping I didn't burn my new supersports in front of the dealership
Took me a week but its like clock work now. LOVE THIS CAR
If you are on a hill, you can use the two step process of partially engaging the clutch first, so it will hold the car, then apply gas while releasing it the rest of the way. Of course, with hill holder, it is much easier now.
Have fun!
Michael
