Manual trans people: normal for clutch to stick sometimes?
Hello all, have a Z51 with 2600 miles on it.
About 500 miles ago, it started developing a potential issue where the clutch will 'stick' near the top of the pedal, then pop / unstick a couple of seconds after a shift to 2nd gear. Hard to explain, but it kind of feels like as if you are shifting to second there is gum on your shoe because it feels sticky.
Also, after driving it moderately... As in a few WOT bursts here and there, it seems the clutch pedal doesn't fully come up and return to its normal travel distance. If I use the top of my foot to bring it forward, it will pop back into place. It's happening more and more lately as well, and I'm even noticing more clutch chatter on 1st gear starts when the car is cold (55* outside).
Hoping this is normal, then again, hoping it isn't so I can have it fixed because it's kind of a weird thing that I'd think shouldn't happen...
I had that problem years ago on a British Ford. In my Ford's case it was a metal shaving in the slave cylinder, and the sticking got worse and worse. Easy fix to replace the cylinder but not something you'd want to let go since it could leave you not moving in a difficult situation. (I know this because my then-wife was told not to drive the car while the new part was on order and did so anyway, leaving it stuck in the middle of a huge, icy puddle until I crawled underneath with a small hammer and tapped the slave cylinder to free it. To repeat: ex-wife, though this wasn't the only problem.)
I am only at 475 miles and no hard driving yet. I plan on turning it loose some today when the streets dry up.
We fought this problem some in the C5 and C5ZO6 especially on the road course. Sometimes the clutch fluid would get overheated if you were really running the car hard, check your clutch fluid level and color i wouldn't think it would be dis colored yet. In the C5 and C6 we changed the clutch fluid frequently to help with this problem. I have not studied the clutch setup (clutch master cylinder location, routing of the line from m/c to slave etc.) if heat could be overheating the fluid. Of course like others just said you got warranty you might want to take it in. I don't want to recommend this yet, but if I experience this problem the first thing I will do is change the clutch fluid to higher temp fluid. Good luck and I am subscribing here to see how it goes for you.
I don't have this issue.
E-Ray, 3LZ, ZER, LIFT
Received 9,653 Likes
My clutch is fine. Already checked with the large Chevy, BMW, Mercedes dealer in town (who had no allocation of C7's) and they currently don't have a Vette mechanic (they had a good one.) If it were mine, I'd drive the 120 miles (up I95 so would have limited clutch usage) to my very large purchase dealer. Thier sevice manager has been vary helpful on the few questions I had.
This is routine for us C6 owners, might give it a try......
Ok here is an update as to what I have done.
This morning I went to Wal-Mart and picked up a Mix-Mister syringe and a couple of bottles of Prestone Synthetic DOT4 brake fluid. I decided to try the "ranger method" of flushing and replacing the clutch fluid.
Keep in mind I have 2600 miles of city-only driving. Maybe 200 of those miles are highway. I don't baby the car at all. After a couple mods, the dyno shows I'm putting out 449 HP / 451lb-tq so it's not stock power output either.
Anyway, I sucked out the clutch fluid and it was pretty brown already. I continued to exchange the clutch fluid until it was clear.
I took it on a nice drive (where I saw 1 C5 and 2 C6's, non responded to the wave and didn't even look at the car.. I'm over the corvette wave thing as no other vettes have ever acknowledged the car in 2+ months, whole other story) and gave the car plenty of time to warm up. Some normal driving and it seemed to improve the problem and the clutch felt brand new.
It was only towards the end of my 40 city mile cruise and getting on it a bit on some back roads did it barely stick shifting from 2nd gear. The oil temp was 225* so the car was definitely a bit warm from getting on it a little.
The flush was a huge improvement, but I won't tell until I do more driving.
I'm just a bit surprised the fluid was brown after only 2600 miles. I hope this isn't the norm.
had no issue!
OP, unless you've accumulated all those miles 1/4 mile at a time, that is not normal. For sure the hydraulic system needs to have the fluid bled as part of regular maintenance, but under normal street use your clutch should not be sticking after only that many miles. With heavy track use, then you likely will have issues fairly quickly if you don't purge the fluid.
