My C7 is overheating
There has been two generations of Corvettes built since the C4, and they are previous generations to the C7. He did state that his old C4 LT1 had two sensors, but since the last two generations didn't have two sensors......
My C1 and C2 and C3 and C5 and C6 didn't have two sensors............
Not saying the C7 LT1 doesn't have two sensors but the odds are 5 out of 6 that it won't.........if you look at previous generations, which he referred to.
Received 8,997 Likes
The C5/C6 had one sensor. The ECM would read the sensor and send a digital data stream to the IPC and the HUD. The IPC would do an electrical digital to analog conversion to feed the analog gauges, the HUD converted everything but the speedo info from digital to analog while the DIC just displayed its info with no conversion. Much simpler design.
Here is the description of how the C6 IPC gauges get their information.
Engine Coolant Temperature Gage
The IPC displays the engine coolant temperature as determined by the engine control module (ECM). The ECM monitors the engine coolant temperature sensor. The IPC receives a serial data message from the ECM indicating the engine coolant temperature. The engine coolant temperature status message is also displayed in the DIC. The engine coolant temperature gage defaults to the lowest position possible if:
As for the OP the DIC readings of the oil and coolant temps are in the correct range. He can avoid calling the tow truck (and the major PIA of getting it safely loaded on the truck) and just drive the car to the dealer. Oil temp is the critical temp and if there is a real issue with the cooling it will climb high and fast. On top of that if the ECM detects the temperature as being too high it will put the car into limp home mode which will prevent damage.
Bill
Bill, I believe that they may have used the two sensor set up on the '92-'97 LTx motors due to the reverse cooling feature of that engine. On those engines, they used reverse cooling to feed the cooler water to the heads first to prevent detonation due to the higher, 10.5:1 (LT1) and 10.8:1 (LT4) compression ratios. I can't recall at the moment what the comp ratio is on the Gen V. But on the LTx motors, discrepency between the analoge and the digital was commonplace, and the digital was the one we look at more closely. That was the technology of the time.
I believethere was only one temp sensor on my LS1 Camaro, so this is probably true of the later editions of the LS series. However, this car did not have a digital read out either.
I do agree however, that this should be looked at.
What is the OP's ambient? To get to 250 after only a few minutes would likely be a false reading. With the thermostat still closed, it takes me a 10-15 minutes of idling to get to a decent coolant temp when its cold out.
Pfadt Race Engineering
888-972-2464
info@pfadtracing.com
888-972-2464
I understand the analog temp gauge gets it's positioning directly from the ECU. Since the vehicle can change units of measure, but only has a single numerical range, I'd assume the ECU does the calculation & outputs the voltage to position the needle accord to which units are currently selected.
Is this correct?
Is this correct?
Can the OP say whether or not his engine fan was running when he pulled over & shutoff the engine? I noticed my engine fan running last night when I got home & ambient temps were 35°F... Never saw my cooling temps. last night but will watch it today. I'm thinking if it needs to run the cooling fan now, it's gonna have hell when it's 105°F in July....
I'm not sure if it was reverse flow cooling or simply different pieces of information. On the LS they moved the temp sender to the forward part of the drivers' side head. On the 90's LT1 the senders were in the water pump (digital) and passenger head (analog). This may have been a partial carryover because in the L98 there were two but one went to the computer and one went to the gauge.
On the 2014 LT1 I know there is a temp sender again in the water pump. I'm not sure if there is a secondary or not.
It seems to me the head would give more accurate overall temperature while the ones in the front (90's LT1 water pump, L98 was near the water pump, and the new LT1 is water pump) would give better data as to when to run the fan(s).
Yes, I'm dropping it off at the dealer this evening and they will look at it tomorrow. I sent them the picture and their Stingray Engineer said he would be comfortable with me driving it there as long as it has Coolant at the normal levels in it.... I'll check coolant levels this evening.
update
Started it up when I got home this evening and now everything is operating in normal parameters. pic below.
Notice the voltage is now normal too. I think someone picked up on it being too high in the first pick. maybe the voltage problem was the source of problem.
a few weeks ago when I had PTM and rear axle issues the code in the computer was a high voltage code.
I'll keep an eye on it now to see what happens.
Made it about a mile this morning and noticed my temp was very high. Pic below. I pulled over let it cool back down and then took it back home to get a different car.
Any one else experience this? Are the two temperatures pointed to in the picture supposed to be the same? When I put my hand on the engine it didn't feel warmer than normal.
The car has been garaged during the cold weather so nothing should be frozen in the car. Any suggestions on what to check before I call the tow truck to get it to the dealer?
My C7 is Z51, M7
My C7 is Z51, M7
#33
It seems odd that these warnings and strange gauge readings are happening.
#35
Not to change the subject but I want to have the same look on my instrments (where you have the arrow pointing) but have not been able to find and apply. Can you give any hints/ideas how to do this? Thanks!
