Z51 or not?
#62
Not sure what size are on the non Z51 but you could go into Tirerack website and look up both to give you the difference.
#64
Banned Scam/Spammer
#65
rotor cost- dirt cheap
Amazing if some one posts anything negative they are immediately a troll.
Consider this: two heavy duty 2011 C6 Z06 rear rotors will cost you your lungs. Check out the cost at GM parts house. You can probably get them cheaper from EBC.
If you replace all four rotors and pads it is very possible that you will be looking at a material amount of money. Dealers usually charge list price. $ 2,500.00 is quite possible and I always look for a bargain.
The new C7 Z51 has brakes which are comparable. If you utilize EBC the rotors should be cheaper than direct replacement from GM but a four wheel brake job will be expensive......
My suggestion is to spend some time, do a search and look at the cost of parts....... and yes you can get cheaper rotors & pads but sometimes you get what you pay for....... cheaper rotors usually weigh more and now you have more rotating mass.
as the old saying goes......
"If you want to play you have to pay".
I find it frustrating that most of you on this forum only want to read what you want to read anything else is put down.
#67
Why would you give this guy any credence. He thinks non-z51s have no center front air dam, whereas it's exactly opposite. Zs have no center dam to allow air to get to all the rear coolers and equalize lift distribution (I have heard both as reasons for the absent Z air dam section.). Not to mention, numerous posters have found brake parts far lower than he quoted.
#68
I am a few months away from putting my order in (2LT Z51) and I have read a number of topics on this and I always come to this conslusion. WHY WOULD YOU NOT WANT IT?
Dry Sump
Rear Diff Cooling
Better Brakes
If I am not mistaken those are only on the Z51 package and make it worthwhile for the price if you ask me.
Dry Sump
Rear Diff Cooling
Better Brakes
#69
Dry Sump
Rear Diff Cooling
Better Brakes
Dry Sump
Rear Diff Cooling
Better Brakes
1. Dry sump? Why? 3 more quarts as a DD? No thanks
2. Diff cooling? Why? As a DD it does not need to be " more cooled "
3. Better brakes? Are mine bad? They stop me fine.
I don't diss anyone for buying z51, I just wish those that did would stop looking down their nose at those of us that did not.....it's childish.....
#70
Why? Realize some people has diff needs than you..
1) I dont live in a world where 3qts of oil means my family does not eat Also I may track my car one day, but even if I dont its good to know I have piece of mind when I am out with spirited driving.
2) With any performance vehicle any time you can cool fluids its a plus. DD or Track Car if I can get a Transmission and Differential cooler I would take it. I used to have e92 335i and there was a VIN split of when BMW were putting on fluid coolers from the factory. Tons of people with early models that just DD'd their car had issues where as people with the cooling units did not just because the car ran a lot better.
3) No one is saying the stock brakes do not work, but an upgrade is always a plus. Would I take single pot brakes or 6 pot BREMBO? They both stop the car...
Also I dont think anyone is looking down their nose. It just seems like a no brainier to have these added items on your performance car.
#71
But I honestly don't need them.....and not saying you are looking down your nose, but that prevails here at times.....along with people who buy AT'S.....rediculous ......
#72
Banned Scam/Spammer
#73
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
#74
Dry Sump
Rear Diff Cooling
Better Brakes
Dry Sump
Rear Diff Cooling
Better Brakes
#75
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
#76
I myself will be getting a Z51, but only because I much prefer the wheels. If they had the Z51 wheels as an option on the base, I'd be all over it .
#77
Why do you want the mag ride? It's been stated numerous times on the forums that the base C7s ride is smoother than a Z51 with mag ride. Specifically, most people seem to be getting the mag ride to be able to get the Z51 package while simultaneously getting a smoother ride for comfort as a DD. So if ride quality is a concern, getting a base is probably better for you.
#78
Reasons for Z-51 for me, I may or may not track the car, so that is not my reason.
I like the wider spoiler, I like the rims and tires better, and the black ones only add 500 dollars. The option pack on up graded rims to black is not much more than a good set of black rims in that size, with matching tires. Then add in the z51 spoiler.
Plus I really like Magnetic ride, at least that which is in my Range Rover. I also think more cooling is always better.
The way I look at it, this is my frist never previously owned Corvette. In the big picture 2800 dollars is not that much when you look at the over all cost of the car, especially with the LT3.
Its not a make or brake me getting the car, and its not much money over 60 months.
#79
Okay, I did exactly what you suggested. I priced out Stoptech performance street pads and Stoptech Sport slotted rotors for for all corners for a 2011 C6 Z06. The cost, before shipping and taxes was..................................... ...... are you ready?.................................. .....................
$740 to replace the pads AND rotors on all four corners from TireRack. Pretty close to 1/4 of the cost that is being questioned. And while the new C7 does have great brakes, they are not CCB's or anything else exotic. So no, I still don't believe $2500 is anything CLOSE to what a basic brake job will cost.
And you wonder why we called the post a troll comment? You might do YOUR due diligence and tell us what you get for pricing.
The cost quoted was what the dealer would charge. Maybe you should re-read my post. Do you know anything about rotating mass and the weight of rotors.
Why don't you check the weight of the stoptech rotors and compare them to what is on the car. YOU GET WHAT YOU PAY FOR I am done there is no reasoning with anyone who has a closed mind
