Question for C6 to C7 owners
I was driving my 427 today on the interstate and was experiencing probably the only thing I wish was different about my car and wondered if the new C7 is better. The problem is with the extremely wide tires on the 427, it wants to really wander on the roads unless on a very smooth road. I'm guessing that the narrower tires on the C7 would probably ride and track the road much better. I can remember when I went up in tire size on my former NSX and it basically did the same thing with the wider tires. It honestly was much more pleasant to drive with the stock tires than the upgraded wider tires. I can't help but believe the Chevy engineers might very well have had this characteristic in their list of things that could be better when they designed the C7 with narrower tires. I love the look of the big wide tires, but I'd bet anything the car would track the road much better with narrower tires and if the suspension is designed from top to bottom to work with narrower tires, wider is not going to be necessarily better. For those C7 owners that might have come from a wide tire C6, I would like to hear your thoughts on this. Thank you.
Coming from my supercharged 05 C6 with Z06 sized rear tires, I can tell you the C7 feels a lot more stable. It will still want to track with some road irregularities, but definitely not as much as my C6. I'm sure it's not just the tires, but improved suspension and aerodynamics as well.
Have your alignment checked. A few yrs ago while getting new tires I had the alignment set to the street specs from Pfadt and I noticed a huge improvement on the hwy.
My C5 had narrow tires(like the C7) and it really tramlined bad with the OE Goodyear's( way, way worse than my wide tired Z06) but 90% of the tramlining disappeared as soon as I installed Michelin A/S tires on the C5.
My experience has been that the C7 Z51 is far better on the highway than the '08 Z06. Also, in 27,000 miles I got 8 or 9 ( lost count) punctures from nails/screws in the rear tires. The C7 tires are plenty sticky so I'm not expecting miracles. Road noise is also much better and driving in the rain is less of a challenge.
2008 Z06 1; stock GYs
2: Nitto NT05, 345 rears
3: Michelin PSS, 345 rears
