Noob question regarding jacking up your C7?
I just put in the jacking pucks into the four holes at the corner of the C7 and had two questions...
1, the jack I have is a lighter duty jack and has a smaller cup (the contact point between the jack and the vehicle) than the diameter of the pucks. Anyone know if its safe to use the jack? I'm guessing the downward pressure of the vehicle will hold it in place even if the pucks do not fit inside the cup on the jack?
2, Once I raise the car with the jack at the point of the puck, where does one put the jack stand? Looking beneath the vehicle, I do not see a suitable location to put the jack stand.
Any help would be greatly appreciated!
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
I don't use a jackstand at all.
From his pic, it looks like I have the same Harbor Freight jack that Glen has and I simply place a piece 2 x 6 between the jack's arm and frame, release the jack slightly to place much of the load on the wood and it is perfectly safe.
Of course, I only jack one corner at a time with this method
Received 8,930 Likes
Take a look under the cradle. That is where you install jackstands on the C5 and C6 and I don't see why they would change it for the C7. Probably the same rules apply. Don't support it under just one rib but make sure the jackstand is located under two ribs of the cradle so you aren't putting too much load on one aluminum edge. No need for cross beam adapters.
Bill
