Wider tires
Old 11-17-2013, 08:42 PM
budgreen3564
Support Corvetteforum!
budgreen3564's Avatar
Default Wider tires
Has anybody put on bigger tires? What the biggest size these wheels will hold.
Old 11-17-2013, 09:06 PM
jschindler
jschindler's Avatar
The problem is finding tires with the width and height that works. Going up one size to a 305 is probably the only real upgrade that makes sense - it will be slightly wider and slightly taller. It's the same issue the C6 had. Some folks went to Z06 tires on the C6 coupe (before the Grand Sport). They would go on, but I never liked them. I had them for a short time and downsized back to a size just one size up.
Old 11-17-2013, 10:04 PM
gthal
gthal's Avatar
Received 1,170 Likes on 486 Posts
And if someone goes 305 you probably actually reduce traction because the PSS tires for the C7 Z51 are a different and stickier compound than regular PSS tires. I would bet a 305 PSS would have less grip than a 285 PSS designed for the C7. If someone goes wider (until the equivalent compound and wider PSS are released for, say, the hi-po cars), they are doing it for looks alone.
Old 11-17-2013, 10:14 PM
glhs386
glhs386's Avatar
Keep in mind squeezing wide tires on a narrow wheel is bad for at-the-limit handling behavior. Either do it right with a matching set of wider wheels or not at all.
Old 11-17-2013, 10:40 PM
DREAMERAK
DREAMERAK's Avatar
St. Jude Donor '12-'13-'14, '16
The new Porsche GT3 will use a 305/30 ZR 20 cup style rear tire and the previous gen used a used a 245/35 19 front, if Michelin's new Pilot Sport Cup 2 is made in both sizes (almost a certainty) this could be a possibility for track guys, or people who want ultimate traction and don't care about the costs.
Old 11-17-2013, 10:48 PM
glhs386
glhs386's Avatar
Running that much stagger on a car with 50/50 weight distribution would be a formula for understeer. No bueno.
Old 11-17-2013, 11:08 PM
budgreen3564
Thanks all
Old 11-17-2013, 11:21 PM
DREAMERAK
DREAMERAK's Avatar
C7 Z51 has a rear weight bias, or go to 255's or 265's up front
Old 11-17-2013, 11:35 PM
glhs386
glhs386's Avatar
49/51, big whoop, the point is it's not 40/60 or more like a 911. You'd probably have to go with a 275 up front to maintain the factory handling balance with a 305 in back.
Old 11-17-2013, 11:47 PM
DREAMERAK
DREAMERAK's Avatar
305 is 20mm wider than stock, add 20 up front= 265, until someone trys it we won't really know. would be interesting to see how mrsc, e-dif, ptm ect react
To Wider tires
Quick Reply: Wider tires
