Go Back   Corvette Forum > C7 Corvette > C7 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C7 Corvette Discussion not covered in Tech Sponsored by
Kerbeck Corvettes
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-14-2013, 12:44 PM   #1
Y2K+1 Vette
CF Senior Member
Default C7 dies in middle of road - 2nd major problem
Sorry to report that I've now experienced my second major problem wiht my C7. My car is an early VIN (low 300s) and first problem was a bad fuel sending unit which had to be replaced with only 40 miles on the car and took 5 days.
This morning on way to work (670 miles on car) it just dies when coming to a stop. The RPMs just dropped down to zero and it died. Put it in park and started it again (although it didn't want to start). Did same thing at next stop light. Again, it didn't want to re-start, but it did. So I figured I would try to limp home, trying to keep the RPM up when slowing (mine is an automatic) by putting in neutral. Needless to say I didn't make it home and it died in the middle of the road and would not start. Had to get it towed to a local dealer and there it sits for now. We will see what they say.
Any thoughts or input would be appreciated. I started loooking thru the issues thread, but there are so many pages now I figured I would try a separate post. Many thanks for your time.
Y2K+1 Vette is offline   Reply With Quote
Old 11-14-2013, 12:46 PM   #2
MikeyTX
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14
Support Corvetteforum!
MikeyTX's Avatar
I'm in ........
__________________
Bearcreek, MT Sept. 2012 across from the Hungry Bear Cafe. Great eats, great hosts.
MikeyTX is offline   Reply With Quote
Old 11-14-2013, 12:48 PM   #3
rcallen484
CF Senior Member
rcallen484's Avatar
Probably related to the gas gauge issue you previously experienced
http://forums.corvetteforum.com/c7-g...e-problem.html
but it will be interesting to find out what it turns out to be.
rcallen484 is offline   Reply With Quote
Old 11-14-2013, 12:49 PM   #4
MeanDean43
CF Senior Member
MeanDean43's Avatar
How sure are you that they 'fixed the fuel sending unit'? Sounds like 'NO GAS' to me.
MeanDean43 is offline   Reply With Quote
Old 11-14-2013, 12:50 PM   #5
harry2
CF Senior Member
harry2's Avatar
Wow that hurts, hope it is fixed quickly and you never encounter another issue!
Keep us posted and let us know what caused the problem and the fix.
harry2 is online now   Reply With Quote
Old 11-14-2013, 12:52 PM   #6
CorvetteBradley
CF Senior Member
CorvetteBradley's Avatar
tbradley2012 tbradleysr
dang we all will be living in the shop in a minute
CorvetteBradley is offline   Reply With Quote
Old 11-14-2013, 12:54 PM   #7
VETJAZZ
CF Senior Member
VETJAZZ's Avatar
That sucks! Fingers crossed you get it back soon and are done with these issues.
VETJAZZ is offline   Reply With Quote
Old 11-14-2013, 12:57 PM   #8
MikeyTX
CF Senior Member
MikeyTX's Avatar
Quote:
I may be the lucky one ............ Mine is so far down the list, they haven't cut the tree to lay the keel so to speak ..........
__________________
Old 11-14-2013, 01:04 PM   #9
rcallen484
CF Senior Member
rcallen484's Avatar
Quote:
Actually, there is no shortage of "lucky ones" who already are driving their C7s who have reported so right here at CF.
Old 11-14-2013, 01:08 PM   #10
BlueOx
CF Senior Member
BlueOx's Avatar
Has the OP tried to put gas in the car? Is it possible this gas gauge issue from before is misreading the amount of gas in the tank and it is empty? The symptoms would certainly follow that notion.
BlueOx is offline   Reply With Quote
Old 11-14-2013, 01:20 PM   #11
DREAMERAK
CF Senior Member
St. Jude Donor '12-'13-'14
DREAMERAK's Avatar
Quote:
or bad fuel?
DREAMERAK is offline   Reply With Quote
Old 11-14-2013, 01:29 PM   #12
BlueOx
CF Senior Member
BlueOx's Avatar
Years ago I had a relatively new SUV and had exactly the same thing happen to me. It just stopped and yet looked like it had about a quarter tank of gas. I had noticed that the gauge seemed out of place a time or two before so I got a gas can and put about 3 gallons in it. Started and ran fine. Fortunately, it was under warranty and they ended up replacing the whole tank, which had the fuel sensor inside of it. Just a thought...
Old 11-14-2013, 01:31 PM   #13
Y2K+1 Vette
CF Senior Member
Pretty sure it is not out of fuel. I recently filled up and always keep an eye on the fuel range. It shouldn't be anywhere close to empty.
Also when I tried to re-start it each time it really seemed like the battery was dead or there was some electrical issue. It couldn't even try to crank. No word from dealer yet although I did give them the info on the prior problem when I dropped it off. Thanks.
Old 11-14-2013, 01:35 PM   #14
BlueOx
CF Senior Member
BlueOx's Avatar
Well, good luck and keep us informed.
Old 11-14-2013, 01:40 PM   #15
rcallen484
CF Senior Member
rcallen484's Avatar
Did you take it to the same dealership?
Old 11-14-2013, 01:41 PM   #16
Hirohawa
CF Senior Member
Hirohawa's Avatar
So what's your great suggestion?
Same thing happened to my C5 Z06 when basically brand new. If memory serves it was my alternator that died causing the car to lose power and shut down on the highway. See experiential vs assuming he did something wrong.
Hirohawa is offline   Reply With Quote
Old 11-14-2013, 02:00 PM   #17
speedlink
CF Senior Member
speedlink's Avatar
Y2k, sorry to hear all is not well. I'm sort of with the others that are leaning with a fuel supply problem.
The low battery you experienced is probably the result of the repeated starting tries you needed. Just a guess.
Wondering if the the dealer actually did replace the sending unit?
Keep us informed what they find. Sorry for the frustration.
speedlink is offline   Reply With Quote
Old 11-14-2013, 02:07 PM   #18
MikeyTX
CF Senior Member
MikeyTX's Avatar
Quote:
Well aware of that. I am on here daily as are you. Have a great day.
Old 11-14-2013, 02:11 PM   #19
sam90lx
CF Senior Member
sam90lx's Avatar
Quote:
Originally Posted by speedlink View Post
Easily entertained huh?
sam90lx is online now   Reply With Quote
Old 11-14-2013, 02:21 PM   #20
Shaka
CF Senior Member
Shaka's Avatar
Send a message via Skype™ to Shaka
Most Corvette buyers are repeat buyers. You would not believe how much went wrong with 70 and 80s Vettes, yet we kept on coming back. Once they were fixed, they stayed fixed. That was the joy of owning a Vette. Since the 90s they have been pretty dependable. The LS engines are no good for Hot Rods or racing unless you get the cast Iron block versions.
It remains to be seen what the C7 and the new LT1 bring.
The 63, the 68 and 84 new releases were dismal. The first and second LT1s were amazing. The C5 and C6 initial releases were uneventful. The C5 was more dependable than the C6 on the race track.
We live in different times now and we are older and our expectations are higher despite the ever increasing complexities of the new cars. I've loved all Vettes till the C7, mostly because of it's looks. If it has major mechanical flaws also, I will stray.
I put a LS2 engine in my roadster and it was totally inferior to my LT4. Could not get it to run cool.
I sure hope the 3 gen LT1 holds up. We shall see this year no doubt. I think a lot of the race boys will go with a stock diff.
Shaka is offline   Reply With Quote
Reload this Page C7 dies in middle of road - 2nd major problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
93 Engine Cutting Out Please Help dtana C4 General Discussion 6 Yesterday 09:52 AM
65 Engine dies won't start or even click. 65GGvert C1 & C2 Corvettes 13 05-18-2014 10:21 AM
I have a mystery problem with my 91 Help!! schmack73 C4 General Discussion 19 10-01-2013 03:56 PM
Electrical Issues or just bad battery? 88Woody C4 Tech/Performance 36 01-09-2013 10:08 AM
Engine dies under hard braking seventysixvette C3 General 16 07-17-2012 12:17 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
