New ZR51 Series Spoiler
Supporting Vendor
We took the C7 to a new level with our newly design ZR51 spoiler. The way it should have come from the factory. Installs using the existing holes on a Z51 car or templates are provided for non Z51 cars. It will be available in a paintable version as well as carbon fiber.
This is currently our test fit model and should be ready for purchase in 3-4 weeks.
http://showstopperaccessories.com/pr...-order%22.html
Looks sharp!
Looks good, but what kind of drag will it produce? It looks like it sticks up in the air a lot more then the stock Z51.
Supporting Vendor
Believe it or not it is only 3/4 of an inch taller on the sides and exactly the same height as stock in the middle.
What wind tunnel tests have you run? Exactly why should it have come this way from the factory?
Received 2,242 Likes
Received 19,572 Likes
'20-'21-'22-'23-'24
Looks very good on the car.
How did you install it? Did you have to remove the rear clip or just drill holes and go through the tail light cavity?:
Supporting Vendor
Supporting Vendor
Received 1,525 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Can I lift my 75 pound Labrador Retriever over this?
