Help! Order Stingray with Stinger Stripe on the hood or Add Stripe Later?
Old 11-06-2013, 12:10 AM
lucative
lucative's Avatar
Default Help! Order Stingray with Stinger Stripe on the hood or Add Stripe Later?
Hi Stingray Enthusiasts,
I like the look of the black stinger stripe on hood for the velocity yellow stingray.
Now, as far as resale value, should I order the stinger stripe with my stingray or should I add it later via aftermarket in case I need to remove it for a potential buyer who may prefer the standard looking hood without the stinger stripe?
Can I buy an aftermarket stinger stripe that can easily applied and also easily removed if need be? I think this would be my best bet? I am also thinking of applying yellow vinyl pinstripes to the black wheel rims.
Is there a vendor you can recommend to me that I may buy an aftermarket stinger stripe from?
Thank you so much for the benefit of your experience
Old 11-06-2013, 12:52 AM
jagamajajaran
Support Corvetteforum!
jagamajajaran's Avatar
Received 9,512 Likes on 2,317 Posts
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
You can remove the factory stinger decal later if you want. It's not painted on the hood.
As for an aftermarket vendor, I am about to receive a sample from one to see how close their carbon flash matches what is already on the C7. I'll post results when I can compare the two if you like. They are a forum supporting vendor. Here's their C7 webpage:
http://www.vettefx.com/c7-stripes-1.html
And I'd say, "Go for it!" If you like it, then do it. It's your car so enjoy it.
Old 11-06-2013, 01:12 AM
Dusty Starbucks
Dusty Starbucks's Avatar
I'm on the fence for full stripes, factory versus maybe later. Nice thing about 'maybe later' is you may never because you like it and if you do it later it makes the car fresh again, to you. It's fun to change a car's look, be it wheels, stripes or other things, but if I knew I was sold on the stripe, the factory would probably be best. Like someone said, it can be removed.
Old 11-06-2013, 07:08 AM
RickConti@Coughlin
RickConti@Coughlin's Avatar
Received 1,554 Likes on 557 Posts
I like the stinger stripe
Old 11-06-2013, 07:14 AM
Glen e
Glen e's Avatar
Get the vette fx metallic black stripe..it matches Carb flash perfectly...mine going on Friday.....as far as the 500 GM stinger, they claim it's paint over vinyl, blah, blah but on the premier edition it looks exactly like vinyl gloss....
Old 11-06-2013, 07:17 AM
zhopper05
zhopper05's Avatar
2015 C7 of Year Finalist
I'd order it.
Old 11-06-2013, 08:50 AM
onthebottom
onthebottom's Avatar
I have ordered it, think it looks great
Old 11-06-2013, 08:55 AM
z51vett
z51vett's Avatar
Cheaper from the factory unless you buy aftermarket.
z51vett
Old 11-06-2013, 09:00 AM
65vette396
65vette396's Avatar
If you want the full stripe look, order it with the car. If you like the hood stripe only, order it from vettefx. I have it and it's a good match for $175. Install is easy as you have an "edge" or hood line on all 4 sides. The full stripe kit would be a pain in the a** to get lined up and spaced correctly doing it yourself.
Old 11-06-2013, 12:57 PM
lucative
lucative's Avatar
I'm the OP. Thank you so much for your suggestiions! I went to the Vettefx website and he looks like a great option for me.
Did any of you by chance order the Vettefx Split Stinger Style Stripe? Do you like it? It looks sharp and unique to me. If you have one, any chance you can post a picture?
Again, thank you all for the benefit of your experience. You are a great bunch of enthusiasts!
Old 11-06-2013, 01:26 PM
676911vettes
676911vettes's Avatar
I have the factory stinger stripe. It is not carbon flash and does not match my carbon fiber roof.
If the aftermarket stripe is carbon flash, it would probably look better.
Old 11-06-2013, 01:37 PM
C6MagRed
C6MagRed's Avatar
That's Mine!!!!!
Be there Saturday to pick her up!!!!
Old 11-06-2013, 01:45 PM
Gr8ful
Gr8ful's Avatar
Can I order the stringer strip from the dealer? How much.? Thanks o lot.
Old 11-06-2013, 02:08 PM
agapsdiver
agapsdiver's Avatar
I got the factory installed Stinger Stripe. It is Carbon Flash and really looks good with the Carbon Flash hood vent. It is a vinyl base stripe and can be removed later if you want.
Old 11-06-2013, 03:22 PM
ATOMICV8
ATOMICV8's Avatar
Originally Posted by C6MagRed
That's Mine!!!!!
You will love that combo that is what I ordered with red interior, you won't be disappointed. Enjot
To Help! Order Stingray with Stinger Stripe on the hood or Add Stripe Later?
Quick Reply: Help! Order Stingray with Stinger Stripe on the hood or Add Stripe Later?
