C7 Jack Pucks In Stock On Sale! Leave-In Style, Easy Install
Old 10-22-2013, 10:52 PM
0corvettemods1
Former Vendor
corvettemods1's Avatar
St. Jude Donor '12-'13
Default C7 Jack Pucks In Stock On Sale! Leave-In Style, Easy Install
As many of you know, you risk damaging your Corvette when you or a shop tries to lift it without have proper jack pads in place. Why take the risk of getting your prized possesion back with damaged rockers?
Our new, lightweight ABS plastic Jack Pucks will save you the aggrevation and you'll know they are always there. Take it to the dealer, a performance shop or the tire shop without worries. You'll always have these pucks ready to protect, invisible to everyone!
Sold as a set of 4, we have these marked down to:
$49.99 A SET!
Click here to order:
http://www.corvettemods.com/Corvette...R-_p_9265.html
corvettemods1 is offline
Old 10-28-2013, 04:17 PM
richscorvettes
Support Corvetteforum!
richscorvettes's Avatar
St. Jude Donor '06-07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Originally Posted by corvettemods1
I have a set from Corvette Mods and they easily snapped in place. They are also just the right diameter and it's nice to be able to leave them in place.
Rich
richscorvettes is offline
Old 11-13-2013, 08:27 AM
MThomas
MThomas's Avatar
How do you remove the pucks once there are installed if they need to be removed?? I know a dumb question but someone had to ask it.
THANKS!!
MThomas is offline
Old 11-13-2013, 09:08 AM
0corvettemods1
Former Vendor
THANKS!!
simply pull them out
Old 11-13-2013, 09:41 PM
AmmoVet
AmmoVet's Avatar
Aren't these made by or the same as BMW pucks?
AmmoVet is offline
Old 11-13-2013, 09:58 PM
0corvettemods1
Former Vendor
Not sure if they are used by BMW. Its possible.
Old 11-21-2013, 11:48 AM
BigJoe
BigJoe's Avatar
Will the ones I have on my C6 fit on the C7? They look the same in your picture and I think I bought them from you a few years ago.
BigJoe is offline
Old 11-21-2013, 11:57 AM
khoeysr
Corvette fan
khoeysr's Avatar
I have a set on my C7.
Great peace of mind.
khoeysr is offline
Old 11-21-2013, 12:39 PM
2 Ag R8Cs
2 Ag R8Cs's Avatar
Location: Retired Suffolk County Police Dept NY South Carolina
I would rather not leave them on and only put on if I need them, are the easy to get off if not needed and put back on when needed?
2 Ag R8Cs is offline
Old 11-22-2013, 12:48 AM
Gr8ful
Gr8ful's Avatar
Why take them off? Extra weight or what. You can't see them unless you are on the floor and they look like the car came from BG with them.
Gr8ful is offline
Old 12-08-2013, 10:25 PM
Glen e
Glen e's Avatar
correct...you cover a hole and they look nice when you are on your back:
Glen e is offline
Old 12-08-2013, 10:46 PM
themonk
themonk's Avatar
Location: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
Received 1,456 Likes on 799 Posts
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
I will definitely buy a set when my car arrives, somewhere along the way the front fender of my C5 got cracked, I'm not letting that happen again.
themonk is offline
Old 12-09-2013, 07:22 AM
2 Ag R8Cs
2 Ag R8Cs's Avatar
I would like to see what they look like up close in person before I decide. If I do not like the looks of the car with them on I would like to remove them after I get done using them and do not need them.
There is a good chance I may choose to leave them on but I would like to have the option to take the on and off repeatedly with wearing out the clips.
There is a good chance I may never need to used them. I had a few leased cars that I turned in without ever changing the tires or fixing a flat but I did get a flat on my Volt when it was 20 months old (probably the first flat in 10 or 15 years maybe longer)
Old 12-09-2013, 12:28 PM
Buzzardz_vette
Buzzardz_vette's Avatar
What is the diameter of the pucks? Also, how do these compare to the aluminum pucks you also sell? Which are better?
Buzzardz_vette is offline
Old 12-09-2013, 01:14 PM
0corvettemods1
Former Vendor
About 3.5" roughly. These are leave in, the aluminum are for usage at the time of need then removed.
Old 12-09-2013, 01:26 PM
Buzzardz_vette
I thought the manual says the puck can't be larger than 2.5".
Old 12-09-2013, 01:47 PM
0corvettemods1
Former Vendor
Went and measured one, The contact portion is 2.25"
To C7 Jack Pucks In Stock On Sale! Leave-In Style, Easy Install
Old 12-09-2013, 02:51 PM
Buzzardz_vette
By "contact portion", do you mean the portion the contacts the vette or the portion that contacts the jack? The manual is talking about the portion that contacts the vette. Other Forums have talked about the limited space to put in a puck in and still clear the body. Have you actually installed these on a C7 and was there any impingement on the body?
Old 12-09-2013, 03:10 PM
rpoz06
rpoz06's Avatar
I have a set on my C7 and they fit fine.......
rpoz06 is offline
Old 12-09-2013, 03:37 PM
0corvettemods1
Former Vendor
Quick Reply: C7 Jack Pucks In Stock On Sale! Leave-In Style, Easy Install
