Plenum and fuel Rail removal
Old 10-30-2013, 05:42 PM
luvlake
luvlake's Avatar
Default Plenum and fuel Rail removal
Anyone know how to remove?
Old 10-30-2013, 10:21 PM
0Andrew6@TheDoubleAA
Former Vendor
Andrew6@TheDoubleAA's Avatar
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
pull up on the fuel rail covers.
Old 10-30-2013, 11:03 PM
luvlake
luvlake's Avatar
How about the Plenum cover? I have custom Plenum and Fuel Rail Covers on order. Thanks
Old 10-30-2013, 11:07 PM
Former Vendor
pull up on it too lol
Old 10-30-2013, 11:08 PM
rcallen484
rcallen484's Avatar
They both just push down into pressure clips of some sort?
Old 10-30-2013, 11:12 PM
Former Vendor
The fuel rails do. I won't be able to check the plenum till tomorrow but guessing it does the same.
Old 10-30-2013, 11:25 PM
George36
George36's Avatar
You will need a 10mm deep socket to remove the 4 studs, pull out the black clips from the plenum cover, really require a good effort. Then just reverse the procedure when you replace the cover. The FRC's just pull off, and snap back on.
To Plenum and fuel Rail removal
Quick Reply: Plenum and fuel Rail removal
