License plate frame?
GM supplies two different front plate brackets. One that mounts in the front grille, and the other that mounts on the nose, like with the C6.
Photos of both were posted not too long ago.
The c7 venders forum has the licence plate frame that is hidden under the car until you want to flip up your plate. I ordered one for 50 dollars. I haven't gotten it yet. I had one on 2011 GS and really liked it.
Don't know where you are from but any frame that allows the plate to be hidden, manually or motorized, are illegal in TX. Check your state law before buying one. (It's a $200 fine in TX, assuming the LEOs enforce it.)
Don't need front plate in Florida but went to put on my permanent metal plate in rear.
On C6 you have two plastic screw holes at top and two rubber bumpers at the bottom to keep plate off paint. The C7 doesn't have the rubber bumpers so I had to make some to protect the paint behind the plate. GM should add that!
Don't know about front frames, but I got a rear frame from Weathertech...the floormat people. It's really well made and has a thick rubber backing so as not to rattle, since we don't have bottom screws on the rear plate mount. Nice stainless steel nuts/bolts with color keyed caps and composite composition of the frame itself...in black.
http://forums.corvetteforum.com/c7-g...cket-pics.html
Received 9,531 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
