c7 oilchange
c7 oilchange
I was talking to the mechanic who does the service work for the c7. He said when he changes oil in the c7 with the dry sump oil system he disconnects the two oil lines going in to the pan from the oil canister to get an extra quart of dirty oil out of the system. He says mosts places where you get your oil changed do not do this. How do you guys do it?
The line that runs from the reservoir through the oil pan line(and the drain) then to the second oil pump(pressure) on my Z06 sags just a little and traps some oil. I just push up on the hose and a couple of oz's of oil will come out the drain. I wait a couple of minutes and do it again. I repeat this until no more oil drains. I would guess I get 8-10 oz of oil out of the line.
Received 4,551 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Joe's method is what I do on my Z06. Very little additional oil drains out. Just let the 2 plugs drain for an extended period and give the line a few taps. No way do you need to disconnect the lines and it certainly won't result in an additional quart if you do.
The C7 dry sump uses the new style ZR1 oil cooler so it does not have the heat exchanger located in front of the radiator or the two oil lines that will trap oil. The C7 does have the same two oil lines as the C6 that run from the reservoir to the oil pan.
I'm about ready to change my oil for the first time at 1000 miles. Does the C7 use the same HP-1017 filter that is used in the C6? Will I still maintain the warranty if I use a K&N filter or Mobil1 filter?
The K&N HP-1017 and the Mobil1 M1-113 fit the LT1 and they will not void your warranty.
Received 19,293 Likes
'20-'21-'22-'23-'24
Thanks for the info. Saving all these posts for future use.
