C7 Z51 real vehicle weights
Anybody actually weigh their C7 yet (truck scale, scale at dragstrip, corner weight scales).....
Post up if you have weighed it, what options your car has, and how much gas in the tank (1/4, 1/2, full tank etc).
Thanks!
Thanks!
Didn't MotroTrend measure the z51 at 3444?
They've been weighed by the mags, it's not some secret. They've all been 3430-3450 that I've read.
If it says
Curb weight 3444lbs(mfr) or (mfr estimate)
then that's the info they were given.
The 3430-3450 is the curb weight of the vehicle, as weighed full of fluids.
If it says
Motortrend $70k Z51 3444lbs
Edmunds. $69k Z51 3443lbs
CarAndDriver $66k Z51 3444lbs
RoadAndTrack $67k Z51 3444lbs
Those all are measured weights according to their sources.
I don't remember these magazines stating that they had actually weighed the cars but rather took the numbers from the manufacturer. I think it still needs to be done and reported here, at least as a confirmation, if nothing else.
Don't disagree that it'd be interesting info.
However, as I said only if it has "xxxxlbs(mfr)" is that what the company told them. Beyond that, I believe all 4 of those sources has specifically said thew weigh all their test cars in the past. I know for a fact motortrend does for all their's.
So every car had the exact same amount of fluids and fuel when they "weighed" them? Or did they all test the same car same day? The real deal will be someone posting a pic of a C7 on an actual SCALE.
I will put mine on my wheel scales as soon as BG ships it to me.
