*Glove Box* access
Old 10-16-2013, 01:15 AM
0Andrew6@TheDoubleAA
Former Vendor
Andrew6@TheDoubleAA's Avatar
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
Default *Glove Box* access
As most folks know the glove box will only work if the key fob is in place and if in valet mode you can not access it. In the future I can forsee someone having an issue accessing the glove box due it something not working. While in the midst of my tear down I found this handy lil thing.
If you open the passenger door and look at the flat panel there is a small cover. Remove the cover and use a long screw driver and push in and it will release the hing holding the glove box.
See Picture:
Old 10-16-2013, 07:08 AM
Xitablboy
Xitablboy's Avatar
See Picture:
DAMN, Andrew....you know this rig INTIMATELY now! Thanks!
Old 10-16-2013, 07:49 AM
Speednet
Speednet's Avatar
Nice tip, thanks.
Old 10-16-2013, 08:00 AM
Former Vendor
lol yes sir, I can tell you quite a few things that most don't know. Also not sure how many people know the fuse panel is in the trunk.
Old 10-16-2013, 12:20 PM
NAV
NAV's Avatar
It has a trunk?
Old 10-16-2013, 12:31 PM
VETJAZZ
Support Corvetteforum!
VETJAZZ's Avatar
Thanks for the tip, but please resize your pictures before you post. Thks!
Old 10-16-2013, 05:11 PM
LIE2ME
LIE2ME's Avatar
Received 4,558 Likes on 1,640 Posts
Thank the automotive gods!! No more "click, click" from the brake relay every time I step on the brakes...
Old 10-16-2013, 05:31 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,067 Likes on 6,169 Posts
They'd know this if they would read the owners manual. Pages 10-40 to 10-43 which contains the following (and much more):
Rear Compartment Fuse Block
The rear compartment fuse block is in the rear of the vehicle, under the load floor. Lift the carpet and access door in the center of the load floor to access the fuses.
Old 10-16-2013, 11:21 PM
Former Vendor
true story, also why don't photos automatically resize like the normally do.
Here is a picture of the rear "HATCH" area.
To *Glove Box* access
Quick Reply: *Glove Box* access
