new batt.
new batt.
just installed new battery purchased from dealer. hooked per instructions by internet. checked with 2 dif. chargers both showed batt.full charged. no lights come on doors will not open,no reaction to key fob. i am lost.this is on 2014 stingray z51. help,please.
Generally this is because the connections are not tightened down properly. I know this sounds odd....but many have re-checked and tightened connections with success. Also be sure the thin gauge black wire to the (-) pole is tight and not broken. You should also check the 350amp fuse on top of the battery.
Received 4,499 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I hope you removed the black cover protecting the post, lot people don't see it, and the battery not completing a circuit so the car in dead.
Leroyt10 (09-05-2022)
Received 19,226 Likes
'20-'21-'22-'23-'24
Both of the above offer very good advice. Hope it is just a matter of something simple being required to get your car up and running again.
Check that the plate on top of the battery is connecting everything as I found out when I had my battery changed. If it is touching only a little your car may start but the next time it will not. It is under the top black cover.
new bayy.
Thanks guys for all your help. I have done all you have said except the 350 fuse on top of the batt. Is that a fuse that is located on the NEG. cable?
toronto,I was looking all over the batt.could not find any fuse on the batt. dummy me. found it but how do you check it and if it is bad how do you remove it. Thanks for your help.
The following 2 users liked this post by jarv33:
StrykerZ06 (09-02-2022),
Vette Jockey (09-03-2022)
