Anyone have a steering problem ?
When I turn the wheel All the way to the end (like when backing up on a smooth driveway) the steering feels bumpy/jerky & makes noise like when I am on a bumpy road.
The same thing happens turning All the way going forward on a smooth driveway.
Is this normal ?
Does anyone notice this?
Is this normal ?
Same as on C6. Someone said someplace it has to do with front tire width. Don't know if that is accurate, but it is true of every single one, not in any way an individual car thing
Ackerman angles due to the location of the steering rack. Your car is fine. It has little to do with the width of the front tires.
My C6 Z06(with much wider tires than my C5, or a C7) is hardly noticeable, with either the OE Goodyear' or the replacement Bridgestone's. And that was with both the factory alignment or the less aggressive alignment I had done with the Bridgestone's. At full lock on my Z, you can barely feel it.
Is this normal ?
Is this normal ?
Is this normal ?
Is this normal ?
Moderator
It's not a "problem" it is a characteristic of wide tires. When you turn full lock in either direction, the two wheels are scribing two different radii as they travel through a turn. One is turning along the arc and the other is scrubbing along the pavement when it tries to scribe a different arc.
