Did they forget to install my magnetic ride control?
According to the manual, I am supposed to see this when I go to personalization menu and then driving mode
Driving Mode
Select and the following may be
displayed:
. Engine Sound Management
. Steering
. Suspension
This allows the Engine Sound
Management feature to be turned
on or off.
Select Auto (Mode Selector) or Off.
Steering
This allows the Steering feature to
be turned on or off.
Select Auto (Mode Selector), Tour,
Sport, or Track.
Suspension
This allows the Suspension feature
to be turned on or off.
Sport, or Track.
Yet for some reason, I only see engine sound and steering options in my driving mode categories!!!
Driving Mode
displayed:
. Steering
. Suspension
on or off.
Steering
Sport, or Track.
Suspension
Sport, or Track.
The latest revision of the software removed that feature. It was too late to get it removed from the manual. Nothing is wrong. That feature is no longer available.
Oh man thanks. I was getting paranoid. So the only way to choose and adjust this is by choosing a drive mode (Eco vs touring vs track etc)? No way to personalize it I mean?
That is correct. Changing the Driver Mode Selector will affect the suspension feel. It can no longer be individualized.
Steering input,yaw,ride feel...etc. Gm got the mag ride dialed in...NICE...Guys you will love the handling feel and ride of a C7 Z51 with mag ride......This car was soooooo worth the wait!
I guess the exhaust is NOT able to be individualized in each mode either, is that correct ?
All I am able to change is making the exhaust open (loud) in ALL modes.
It isn't just about sound. It is about optimizing the incoming air with the outgoing air and providing the back pressure the engine is looking for for optimum efficiency.
Personalization is limited to basically either as it came from the factory with variation in Weather, Eco or Tour, vs. Sport, vs. Track or Track mode all the time.
I just wanted to change one mode "Tour" to open (loud) and keep the other 4 as they came from the factory. But I guess that can't be done ?
Michael
http://forums.corvetteforum.com/c7-g...-question.html
I am not following this. If you can set it to Track Mode (loud) all the time, then that would be minimum backpressure all the time, thus negating "optimum efficiency". I don't see how increasing backpressure increases efficiency anyway. It will affect charge dilution with exhaust gases (more EGR), but I doubt there is much change given that there are cats in the system with lots of backpressure already.
Michael
Michael
Paul, I'll have to check mine again, LoLa just came off the line this past Monday and she's fine a sassy lady as you could want. BUt I did set the sound in the settings to be 'ON' all the time and it works.
'ON' could mean "tied to the mode" (as Rick T stated earlier) instead of 'OPEN', and 'OFF' well that's obvious. So it is opened based on the mode, but can be closed all the time (all modes), or in any specific mode, if you so choose.
AIR FORCE VETERAN
Why do people threaten not to buy a car unless.....I mean do they really think GM is going to change something to sell them a car? Can you just see them sitting around a table saying "what are we going to do"?
When you say "it works" do you mean the software accepts it, or you can actually hear the exhaust note get louder?
There are just TWO options....#1 is AUTO (factory setting) Changes with the drive mode that you are in.
#2 is OFF which is LOUD in ALL modes.
That is it NO other options !
Hills Start Assist can't be turned off AT ALL. Others have complained you have to turn on Rev Matching every time you get in the car if you want that. Exhaust can't be set for various modes. If these can't be programmed, it takes away a lot of the value.
Michael
They didn't seem to get the message over at Chevy that people like to customize things to their taste. If it is done by computer, it should be programmable. Look at people's smart phones. There are no two alike.
Michael
Michael
