Owners pls tell us about the cylinder deactivation
I have 500 miles on my base 7-speed. Never tried ECO until today at around 65mph in 7th. Very hard to notice at steady speed unless you are paying attention. A slight change in vibration, almost like the type of pavement changed. If you step into the throttle slightly you feel it more but if you step in very much it goes to V8 mode.
In 7th gear with the base gearing 1000 rpm = 54 mph. Yet it has good throttle response at that speed in V8 mode! Amazing
It has to be in eco mode. Honestly, ive had it in both and I have been seeing better mpg in sport mode just tooling around. If I am on the highway at highway speeds it gets a little better, but sometimes the 4 cyl and less power works harder and needs more fuel. Oh well.
You can def feel it kick on and off. It feels like a fuel cut off. If you have ever driven any of the gm trucks with DOD its the same feeling. (2012 Silverado LTZ does the same thing)
In driving my automatic, it is very transparent and not even noticeable. I used the info settings that show V8 and V4 modes when they switch. They only way I knew was from looking at dash.
Thanks for the info. I was hoping the system was transparent. It sounds like it is not a problem so far. There was a lot of drama when we first heard about this feature.
Apparently, people make up a lot more drama than there is. The fact that Eco mode can easily be turned off makes it no drama.
One of the reasons to avoid the automatic is the AFM is to restrictive in the mode selector. It comes on in every mode except track. Had it in my Camaro and it sucked. With the manual it only comes on in Eco.
This system allows the engine to
operate on either all or half of its
cylinders, depending on the driving
conditions. With a manual
transmission, the system is only
active in Eco Mode. See Driver
Mode Control on page 9-38. With an
automatic transmission, the system
is not active in Manual Mode. See
Manual Mode on page 9-28.
Believe me, it's on, you also get a drone when it's on. To meet the EPA requirements, it has to be on all the time. The only way to defeat it is to shift to manual and use the paddles. After having it in my Camaro, I don't want anything to do with it. That is why I got the manual.
1. get a tune and kill it altogether (but lose warranty)
2. get up to speed, shift to manual and paddle your way up to gear 6...
4. get a RANGE AFM module to kill it...I have one for my camaro and Adam says it will work on the C7 fine. ..I'll try it on my way home after I get the car.
you get it, most of the guys here don't - it is terrible on my camaro as you know...there are three ways to get rid of it on a auto C7 at interstate speed:
