Breaking News: Is this the C7 ZR1′s Supercharged Powerplant?
by Paul Huizenga on October 8, 2013
"While there has been speculation about a C7 Corvette successor to the outgoing Z06 using a small-displacement twin turbo V8, as seen in the Cadillac Elmiraj concept, we haven’t heard much about what will power the Corvette that will eventually replace the 638 horsepower C6 ZR1 lately.
And then, one of our Power Automedia fans slipped the photos you see here over the transom (if you’re under 40, there’s pretty much no chance you’ll understand that reference, but we’re keeping it) and we’re ready to fire up the rumormill once again.
The engine in the photos is definitely an LT1-style, Gen V Chevy small block, as evidenced by the injector cover shape and the fact that the throttle body is consistent with the ones used on the C7′s LT1.
And it’s clearly a twin-rotor supercharged engine with the LSA/LS9 style pulley mounted high on the front, and intercooler plumbing also bearing a resemblance to previous heat exchanger setups. Our contact says this came from a “friend of a friend” inside GM’s prototype center, and that it’s a 6.2 liter engine. Don’t get too hung up on the fact it has a conventional engine-mounted transmission instead of a torque tube and transaxle – for testing purposes it’s a lot simpler to use a conventional transmission.
Could it be a clever fake? Possibly, but take a close look at the shape of the back of the top cover, and compare it to the CAD rendering leaked what seems a lifetime ago:"
The Consigliere
Received 5,423 Likes
Hhm.
That's pretty interesting. Seems the more that trickles out the more such trickles suggest a PD huffer for the vette. Still don't know if we'll get one perf model or two.
Next few months will be fun to watch.
