Blendmount radar detector mount in the C7?
Corvette fan
I have used this setup in my recent cars and hope to be able to do it in the C7. I know Blendmount has a special mount for the C6.
For any of you familiar with Blendmount C6 setup and who have seen the C7, do you think the C6 mount will work? Will they need a new design for C7? Is it impossible?
Rearview mirror mount
I have a battery powered RD because I hate cords..it makes the detector heavier...I was wondering how that might play out with the mount I'm thinking of purchasing. I don't remember the name but it mounts between the rearview mirror and it's mount. Any body got pics specifically of the rearview mirror setup?
Corvette fan
My research led me to abandon cordless radar detectors. Apparently in the radar detection business it's all about power, and the battery models just can't measure up.
They certainly do simplify the mounting issue.
Corvette fan
I just got the newest detector from "Escort" and it comes with a very big heavy duty "mount". Check out their site I think you will be impressed with their mount. They are "top of the line" detectors.
Corvette fan
I am assuming those who use the C6 Blendmount also are tapping in the same way.
Corvette fan
That suction cup is HUGE.
Received 1,069 Likes
2015 C7 of the Year Finalist
I used a blendmount on my C6 but have decided not to use one on my C7. I like to mount my detector on the left side of the dash where it is hidden from the rear. I just completed a 3,000 mile road trip with my new passport Max and it worked great. I direct wire into the fuse box of all my cars and use the velcro from ezpass to mount to dash. I find it easier to tranfer from car to car.
Corvette fan
Looking at the pics, that is a really bad setup. Front and back view/sensitivity has got to be poor.
I know it's an awesome detector, but......
I used two detectors, one on dash like picture shows and one on blendmount and they both got the same signal at the same time. Rear detection may be a bit less. i found that my mirror vibrated to much with the blendmount hanging from mirror.
I asked BlendMount about the C7. They have it covered. Use the mirror tap. It gets power from the mirror. Works great. Looks great and picks up thru the back window. I have it on my C5 and will put it in the C7.
E-Ray, 3LZ, ZER, LIFT
Received 9,605 Likes
Getting access to the rear fuse panel takes some effort!
Full set of pics at http://netwelding.com/Reports_Vette_Info.htm if interested.
Waiting patiently for a more elegant solution...
There are no exposed connectors in the rear view mirror area like the C6. It will require some more sophisticated wiring that simply tapping into the mirror connector like before. I pulled off the plastic cover in that area and there is no exposed wiring. I didn't have a whole lot of time when I did this so I didn't dig any further.
