A few interior photos
#41
#43
As per page 2-18 in the owners manual:
"Intrusion and Inclination
Sensors Disable Switch:
It is recommended that the intrusion
and inclination sensors be
deactivated if pets are left in the
vehicle or the vehicle is being
transported.
With the vehicle turned off, press d
on the right side of the hatch
release button. The indicator light
will come on momentarily, indicating
that these sensors have been
disabled for the next alarm system
arming cycle."
transported.
arming cycle."
#44
Very nice. These are the best pictures I've seen of the non FAY interior as well. Do you have any additional photos of the non FAY dash you can share? Can you also comment on the touch and feel of the dash? Does it feel plasticy or high quality? Thanks!
#46
Don't leave your pet in your vehicle in Texas. New law states that if temp is 70 degrees or greater and no persons are in vehicle with animal(s), regardless of whether climate control(a/c) is on or windows are down (partially or completely), then vehicle owner can receive a citation.
#47
Moderator
Looks like that rear cubby is smaller than the ones on the C6. It looks just big enough to hold my jacking pucks.
#48
I'll check tomorrow and see what I can find for you. I have a few others and I'll see what I can share.
#49
E-Ray, 3LZ, ZER, LIFT
Received 9,610 Likes
Great picks! Looks like the cup holder will support a water bottle on the passenger side without it falling over when you make a fast left turn! The ones in the C6 were useless. Now just need to devise a way to keep it from falling on me on a shape right hander! Shouldn’t be difficult to rig a left side support that attaches to the bottom and also supports, front and back. When my C7 arrives will have to consider depending on how well the proper size water bottle fits. Better than the extra cup/bottle holder I had to add to the passenger side of the C6.
#55
Great pictures, thanks. So, just to be clear, the rear, 12v, charger port will require a standard, male cigarette adapter, correct?
#58
#59
They all can connect to the radio. It is optimized for two connected media types among the 3 USB ports and the SD card. Additionally, you can just use it for charging when the device is not in use (selected) as a media device.
#60
Received 4,116 Likes
2020 C8 of the Year Finalist - Unmodified
Talon: I know this was a 2LT and I know the interior was Kalahari but was the exterior Torch red? Any idea if Kalahari and Torch red look good together?
Great shots BTW. Extremely helpful!!!
