does C7 have two part no's for left & right rotors?
No.
Based only on the pics that have been posted, on the Z51's, the rotor slots curve backward on the driver's side and forward on the passenger's side.
Received 8,960 Likes
Doesn't need to be fixed. The C6 Rotors work fine on the track with their single part number. The so called problem has generated a lot of words since the 05 model year but so far no performance issues.
Bill
Bill
eta: Also, perhaps you actually had excess pad material build up on a rotor rather than actual warpage? (just another thought)
A common cause of brake pulsation on all cars occurs after a dealer or shop has removed the wheels. If they are not retightened in a proper sequence or are overtorqued (with a powerful impact gun) they will seem ok at first. But after a few thousand miles you may start to feel pulsation in the pedal. The over torquing causes slight distortion of the rotors and they start to wear unevenly. It really is worth it to re torque wheels by hand any time one has been removed.
so spinning backwards doesnt affect how the "axial" venting style works? just to be clear, i dont mean though the cross drilled holes on the C6, i mean the standard venting style used on pretty much every car. even my crappy ol sedan has two different part numbers for left and right
The upside with Corvette brake cooling however is that there are also supplemental ducts that force low, cool air on to the surface of all of the rotors anytime the vehicle is in motion. Difficult to determine how much added heat the two reversed sets of vanes contribute but a lot of testing in to braking and brake fade are conducted during the design and development process.
I don't know if the direction of the curved vanes has any affect on air movement over the vanes, either from the hub outward or from the periphery inward towards the hub.
It just seems to me that a curved vane has more surface area to release the heat into the airstream(which ever direction it is flowing) then a straight vane.
Aerodynamics are complicated. Supercomputer-complicated when it comes to what's going on in and around the wheel of a sports car on a race track. This is not like a waterwheel on a stationary axle under a smooth spout of water or a paddlewheel on a riverboat.
