Some closeups of the "bare" car at Carlisle
Received 2,222 Likes
First the valves: They are on all models to deal with the sound of the exhaust in 4 cylinder econo mode to make the exhaust sound better.
The slanted downward radiator is in that configuration so the airflow is directed to the hood vent and produces added down force.
If I'm not mistaken, those are used to close off some of the exhaust flow for when the car is in cylinder deactivation mode. They would in theory close/restrict the exhaust partially to create additional back pressure when running on 4 cylinders. These would function separate from the multimode exhaust valves at the exit of the mufflers which operate similarly to those found on the NPP exhaust of the C6.
I am thinking that the valves ahead of the mufflers are related to the variable sound noted when changing the driving modes that also change the level of growl from the exhaust.
Front lift is reduced by tilting the radiator forward, just like the C6.R race car. Gives more downforce. This eliminates the "gremlin" of front end lift at high speeds that the C6 had.
That shows how much I know about aerodynamics... I would have though the exact opposite, that the slant (top-forward) of the radiator (and resultant direction air pressure created by it) would actually create lift... crazy...
Received 3,787 Likes
"Ask Tadge" Producer
Clarification: the simple act of tilting the radiator forward does very little, if anything for aero and down force. What it does, however, is open up the possibility of adding air flow through the front end of the car via vents in the bumper and hood. That is what provides the down force, and significantly better engine cooling.
A couple of good old references are Aerodynamics of Road Vehicles by Wolf-Hendrich Hucho and Race Car Aerodynamics: Designing for Speed By Joseph Katz. Available through your local library by inter library loan.
Jim Hall of Chaparall fame did an awful lot of work with whole vehicle aerodynamics. His story is worth the read.
Some early race car designs had the radiator parallel to the ground with a "bottom" intake and exhausted through the hood.
Note that the new Viper also exhausts through the hood. The Viper GTS-R has huge hood exhausts.
The trick is to exhaust into a low pressure area on the hood and pick up from a high pressure area in the front or underneath the car.
