Corvette Stingray Constraint and Production Update
Old 05-14-2013, 11:40 AM
Ken Fichtner
Ken Fichtner's Avatar
Cruise-in I Veteran
Cruise-in II Veteran
Cruise-In III Veteran
Default Corvette Stingray Constraint and Production Update
Corvette Stingray
Constraint and Production Updates:
•First consensus for dealers eligible for initial allocation of the Corvette Stingray coupe is May consensus cycle 2
–Consensus cycle 2 covers production into August
–All dealers eligible for initial allocation will receive an estimated guide number of at least one coupe
–No consensus during June
•Potential Constraints:
–5 Spoke Chrome Wheel (RPO: QX3) on non-Z51 models
–Other constraints may develop. Please monitor constraint wire for further information
Old 05-14-2013, 04:11 PM
rcallen484
rcallen484's Avatar
Originally Posted by Ken Fichtner
Corvette Stingray
Ken, what does that mean? Can you restate it in another way? Thanks
Old 05-14-2013, 04:22 PM
harley2
harley2's Avatar
Received 1,339 Likes on 590 Posts
Not Ken! lol
From what I understand, on May 23rd, all dealers that are eligible will receive at least 1 coupe allocation!
Naturally, those large dealers that sell alot of vettes will get more then one!!
Old 05-14-2013, 04:25 PM
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It is basically saying the first consensus cycle is the second cycle of May (which is the 23rd as I recall.)
This cycle will cover production build allocations through August.
There won't be a cycle in the month of June so you won't see any new orders added until at least July. This is basically saying you won't see any additional cars allocated to you after the May cycle until at least the first July cycle.
All 900 dealers on the list for the first production allocations should plan on getting a minimum of one coupe in this cycle. If they only built 900 coupes, each dealer would get one distributed equally.
If they go beyond the 900 number they will start distributing those again with the volume dealers and allocate based on prior sales.
Old 05-14-2013, 08:07 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
Love your new avatar, Paul!
Old 05-14-2013, 08:49 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Are you saying that they are going to produce the C7 in May(starting on the 23rd), then not produce any in June and then start producing them again in July? Are the going to take the first two weeks off in July like they use to do(resulting in no production during that two week plant shutdown)?
Old 05-14-2013, 11:00 PM
07MontyRed
07MontyRed's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13,'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
NCM Lifetime Member
Paul, love your new avatar!!
Always good to have you post ... you are one of the good guys!
Old 05-15-2013, 01:21 AM
ZL-1
ZL-1's Avatar
Right now all the dealers' orders are at status code 1100. The May 23rd consensus will select at least one coupe order from each eligible dealer. Those orders leave 1100 and proceed through other statuses for a couple months until they reach status "3800 - Produced". All the cars are stored in the big lot out back. When the lot gets really full a decision is made to release them all for shipping. Sometimes later-produced cars get shipped before the earliest ones. The cars being produced now through June are captured test fleet cars for evaluation. They carry production code WD1 - Pilot Vehicle. At some future date certain WD1 cars have been known to be sold "used" through the GM dealer auction system.
Old 05-15-2013, 02:06 AM
AVETTE
AVETTE's Avatar
Cruise-In II Veteran
Default wow...
I will be in shock if massive allocation dealers like Kerbeck and MacMulkin get ONE COUPE in the initial allocation, especially since MacMulkin has been guaranteed 250 units in the first 6 to 9 months, I know they will "ramp up" more later but really, ONE UNIT???? Seems hard to fathom...
Old 05-15-2013, 02:36 AM
msm859
msm859's Avatar
Each allocated dealer will get at "least" one. That takes care of 900. If they can produce 180 per day x 4 days x 4 weeks in August that would be 2880 total. I suspect the additional @ 2000 will be allocated on a percentage basis.
Old 05-15-2013, 03:01 AM
AVETTE
AVETTE's Avatar
Default Time will tell...
We will know more after the 23rd...
Old 05-15-2013, 01:12 PM
H101
H101's Avatar
It may have been asked before, but I cannot find it. Do we have an idea of the total number of C7s were in the allocation?
We know a tad less than 900 dealers will get at least one car. Watching the posts my wild guess is the average dealer (of the 900) will get about 10. That would say about 9,000 cars allocated in the first 6-9 months. Lets be optimistic and say it is for 6 months, so that would be 1,500 cars a month in the consensus.
So, this post kinda says the first consensus will be for two months production, or 3,000 C7s (all coupes). If each dealer gets 1, that would leave 2,100 or about 26% of the 8,100 allocations left over from the "every dealer gets 1" statement.
If my dealer gets 15, then he could get an additional 3-4 (26%0f 2,100 is 3.6) cars in the first allocation. If that is true, then his total would be 4-5 cars in the first pass. I am number 4 on his list.... Geeeze this could mean I might make the first cut.
I clearly have too much time on my hands :-)
Old 05-15-2013, 01:52 PM
talon90
talon90's Avatar
NCM Ambassador
Exactly correct. Since the final total for the first consensus cycle is an unknown, GM is only committing to the expectation that each of the allocated dealers will get a car (coupe only). Anything over and above that will be divided starting with the highest grossing dealer on a percentage or ratio basis.
Old 05-15-2013, 01:53 PM
talon90
talon90's Avatar
NCM Ambassador
Good analysis and an accurate representation of what could happen.
What isn't known is what that ramp up will be nor what that total will be.
Old 05-15-2013, 02:07 PM
ZL-1
ZL-1's Avatar
Production starts slowly at first. It may take a while before maximum weekly production is achieved.
Old 05-27-2013, 12:23 PM
tbasco 6
tbasco 6's Avatar
I have talked to two dealers, each listed on the Chevrolet site as C7 dealers, and each telling me they are getting 3 coupes. As of 5/25 neither one had received an allocation. Did I misunderstand that all 900 dealers would get at least 1 coupe in the first allocation?
Old 05-27-2013, 02:57 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,067 Likes on 6,169 Posts
No, you did not misunderstand. All of the approximately 900 dealers that qualified for the C7 initial 6-9 months will get at least 1 coupe in this first consensus cycle. If they don't know they got one, they are not paying attention - and may have missed their opportunity.
To Corvette Stingray Constraint and Production Update
Old 05-27-2013, 04:03 PM
AVETTE
AVETTE's Avatar
Default Prepare yourself for HEAVY "market adjustment"
Those who think that "within 6 months" big discounts are coming are seriously mistaken... Watch and learn... perhaps in a year or two those looking to save a few bucks will find a deal, NOT in 2013 and probably not for at least through summer of 2014..., in the meantime, I will enjoy my new Stingray from MacMulkin
Old 05-27-2013, 04:09 PM
harley2
harley2's Avatar
Thanks soo much Tommy Jr @ Mac Mulkin!!
We got a deal, we're in the first build! Barring unforeseen constraints!
We'll know more very soon!!
Old 05-27-2013, 04:25 PM
JoesC5
JoesC5's Avatar
Have you read today's posting from Wes at Reliable Chevrolet? $1,000 off MSRP on his convertible allocations.
Not even in production and you can buy one(when they are in production) for a $1,000 discount. Kind off blows your assumption out the windows.
PS- The first 6-9 month allocations of the C7 are not sold out at the 900 Chevrolet dealers that are receiving them. Plenty of them will be sitting unsold shortly and discounts will be the norm before the 2015's go into production next July.
Quick Reply: Corvette Stingray Constraint and Production Update
