Both roofs?
Both roofs?
Just coming out of a C6 convertible and going to a C7 coupe but I'm undecided about the two roofs. Did you get both and use them for different reasons or does one always stay in the garage? I like the Carbon Fiber for color matching purposes and the Transparent just to have kind of a sunroof effect.
What's your opinion?
Pick one and go with it. I always found storing a second roof in the house a hassle.
I'd go with the free one and buy a lexan roof off the forum as owners with both tend to choose one eventually.
I then sell my solid free one although this time around...the solid one is lighter 16 lbs of painted carbon fiber so I might stay with that...
If I like the carbon fiber black roof with the painted spears...I'll have the painted roof done and painted black in the middle leaving the body colored spears....
Or some vendor here will come up with a carbon fiber look for the center of the roof..
To answer your question..I like the lexan roof on my c6...as it opens the passenger compartment....I don't like the lexan roof without the body colored spears...
Might be a vendor who offers a painted spear lexan roof option..
2016 C7 of the Year Finalist
Will do both
It really depends on how you plan to use your C7. I will have the roof panel stored in the back most of the time (just like I had the convertible top down most of the time). When I don't have it stored I like to have light come through similar to a sun roof, so I went with the transparent panel only. Plus I like the overall visual effect of the black panel matching the rear window contrasting with my Torch Red body.
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
I had the clear roof on my C6 and put a DSV sunshade on it. Turned the cabin into a green house IMHO. I took the roof out a lot and drove it like that but when the roof was on, so was the sunshade.
Corvette fan
I am trying to figure out how to get all three roofs. I can't order them all with the car. I ordered the dual option (exposed cf and clear) so I will add the body color later if the fever doesn't break.
This input is appreciated as I have never owned a targa type vehicle.
On my C5, I used the clear roof fall, winter, and spring. Switched to the solid roof during the summer, as the heat and bright sunshine turned my ebony interior into an oven. Had a rack on the garage wall for the not used top.
AIR FORCE VETERAN
Exactly my experience. If you have to choose i would recommend you do not get the clear roof.. I never used mine after April or before Oct. you could plant anything you want in the passenger seat a natural grow light..
Exactly. Go with the carbon fiber roof panel. Another reason is that from the looks of GM'er's thread, a relatively small number of people are buying the carbon fiber roof, so you won't see it everywhere you go.
