Electronics questions....
I am not an electronic geek tech type, so forgive me here if these questions seem elementary, but I'm sure there are a few other luddites out there that would like to know...
So, Ok, what exactly is the described "AM/FM/SiriusXM7 MP3 RDS Audio with Memory Package USB/SD card input and input jack" on the spec sheet? Yeah, I get AM/FM/Sirus Xm7...(worthless imho)
What exactly does "MP3 RDS Audio with Memory Package" mean and what is it?
Same question with respect to "USB/SD card input with input jack"?
How do these work? what do you need to make them work?
How do you hook up your ipod to work on this system?
Thanks for your input....
MP3 - This is a commonly used format for digitally storing audio files on memory devices. iPods typically use a different format that is unique to that device (which the Corvette will handle as well). MP3 files compress the data in the music to make a smaller file size so you can fit more songs on a device. Different amounts of compression (bitrate) affect the tradeoff between file size and audio quality.
RDS Audio - Radio Data System (RDS) is a system for providing information along with FM broadcasts. This inaudible information provides such features as program service name, program type, traffic announcement standby, automatic tuning and program type tuning, and is used for various purposes, the most common and basic being to display the current station name, artist, and song that is playing. Not all FM stations broadcast this data stream.
USB is an interface commonly used to connect devices to computers. USB sticks or USB memory or USB drives are terms used to describe small rectangular sticks that plug directly into a corresponding slot. They can have plenty of digital memory to store the above-mentioned MP3 files. Some digital audio players can be plugged in using a USB cable.
SD cards are a different form of memory for holding digital files. They are small thin squares that are inserted into a narrow slot. There are also Micro-SD cards that are truly tiny.
Input jack usually refers to a hole that accepts a single metal cylindrical plug (as is found on the personal earphones that came with your iPod). Different sizes and configurations exist, but the car most likely uses the same type of jack as your headphones... a 3.5mm mini-stereo plug.
I'm stumped by their use of "Memory Package" unless this refers to the ability to index all the digital music files on your plugged in memory device and let you call them up by genre, artist, title, etc.
If the memory package system is the same as the C5's, it means that your presets will change with the driver number you're on.
Meaning, if you are driver 1 (driver key fob 1) and you set your presets, then driver 2 (presumably your wife has the second key fob), her presets would be saved separately from yours. This is how it worked with my C5's memory package. I don't know if that carried over to the C6s.
The memory package stuff like this also extends to seating and mirror positions, as well as the A/C settings.
That makes sense, SCM. But I was puzzled as to why "memory package" was lumped in with all the audio information in the same sentence (as provided by CoupeGuy).
Here's a cute thought... What if the Memory Package settings not only swapped out seat/mirror settings, etc. but also the presets on the radio? Each driver could have their own favorite stations stored.
I don't know of any audio system that does this and I don't actually believe it is implemented in the Vette this way. But it would be a cute extra cherry on the memory sundae and not very difficult to program.
They'll probably be USB 2.0 but I've read somewhere that they're up to 10W so they should charge tablets, etc. I know that's an issue with my phone (Galaxy Note II) - it needs some serious juice to charge up that battery quickly. I didn't see any blue in pictures yet unless GM is ignoring that convention. Apple does.
However, USB 3.0 devices are compatible with USB 2.0, so you can plug in any USB 3.0 devices into a USB 2.0 slot, and it will work fine.
Thank you CaryKen. I'm wondering where the SD card would come into play, my having them only in cameras for photos/video. Boy, this dinosaur has a lot to learn (while parked).
Dan, apparently the Stingray has a slot that will accept an SD card. It's just an either/or alternative to using a USB flash drive (memory stick, whatever). Different form factors, but it's all just memory to hold the bits comprising your music files (or photo/video files in your case).
You should be able to use the same SD card as your camera uses. Except that most cameras these days use the Micro SD format, which is a smaller piece of plastic. There is a cheap/free adapter that lets you insert a Micro SD card in a standard SD card slot.
These standards can easily drive you crazy. For instance, SD users will want to know if the car supports the higher bus speeds of UHS-I or UHS-II cards (See https://www.sdcard.org/developers/overview/bus_speed/). This isn't important for music playback, but could conceivably speed up the indexing process when inserting a card with lots of songs.
http://www.chevrolet.com/mylink-radio.html
