Another C7 Accident
#141
2015 C7 of Year Finalist
Why are you trying to make this so difficult? First of all the Lincoln pushed the Vette. There was no dragging! Second, the Vette was pushed only about a car length after it was hit. Not 40 plus feet! This is very evident by where the debris starts and ends. Third, neither the Lincoln nor the Vette was traveling very fast. Probably in the neighborhood of 10-15 mph. Any faster and there would have been much more damage to both vehicles. And Fourth, to spin a vehicle around, it has to be hit hard at the very front or back corners. When a car is T-boned, it doesn't spin around, it just gets pushed straight.
First - a Question for you - are you telling me the Corvette was traveling on the wrong side of the street? That would be the only way it would have been "pushed" a one-car length. From what I could tell, it was supposedly making a left turn from a four-lane boulevard; do the math - The Corvette's original turning lane plus two on-coming lanes, plus the crosswak, plus it's final stop.
Second - my conclusion as to the "spin" was based on the initial assessment of the prior entry by a former accident investigator who indicated that based on the damaged of the Lincoln, it hit the Corvette at its corner at the front of the Corvette's door then skidded to the back. If that is the case, the Corvette would have to be pushed in a circular motion, and not necessarily a full 360-degree spin.
Third - I don't buy the analogy of all of the debris continue travel until the resting point. Because, technically speaking, once the Lincoln supposedly made impact with the Corvette, some debris that launches forward and sideways due to the original impact, initially at the speed of the Lincoln, would bounce back off the Corvette body and cease from traveling at the same speed of the Lincoln, and therefore creating a field of debris over a wider area than shown (see the picture of the Yellow Corvette - look at the track of debris).
Fourth - the apparent dents. All you have to do is compare the condition / appearance of the yellow Corvette. Do you see dents all over? Or cracks? The door panels of the C7 should have cracked due to the several sharp corners hitting it repeatedly due to the presumed "push". The damage on the door looks more like an aluminum-door damage.
Finally - I would think, by now, someone would have come forward with pictures of the Corvette on a flatbed.
I am sorry, but with all due respect to the experts, I am just not convinced.
#143
"This is the most serious crash to date" involving the new 2014 Corvette, said Monte Doran, a GM spokesman, in a phone conversation on Monday.
#144
AIR FORCE VETERAN
Now that is a weak suck pick-up..to get hit in the middle and spin. I wouldn't buy another one of those if I were you..or maybe it is a magic truck that gets hit dead center like a pool ball then spins around..
#145
Not a Left Turn
I believe that the Vette was stopped at the light and decided to make an illegal U Turn. He pulled out in front of the Linc which slid on wet pavement. The accident happened exactly where the debris is located.
#147
This is the type of response I'd expect from a teenager...like perhaps your alter ego drmustang. It's physics, "Bill". If the truck is hit in the middle, but most of the weight is over one end (in this case the front), the vehicle will spin around the axis of the weight, in this case the front tires. Pretty simple.
Not sure what any of this has to do with the perceived quality of the vehicle...
#148
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
#149
You are absolutely right. I should have said that a vehicle "normally" doesn't spin when T-boned at "slower speeds".
#150
http://www.edmunds.com/car-news/gm-e...eet-crash.html::
#151
Yes, I did check the link. it turned out I was apparently wrong and it's okay. By the way I was not ranting - LOL. I simply raised a number of legitimate questions, that out of curiosity wanted to get answered.
#153
Note this post was a joke for those who find it difficult to read peoples sarcasm or between the lines, I was in a playful mood when I saw this thread and someone had me going on thinking the picture was "chopped" but now when I think about it everything is photoshopped ... if anything to help better the lighting on a sub-par picture or zoomed in for a better closeup etc ...
#154
Received 2,225 Likes
