2015 z06??
Old 07-12-2013, 02:49 PM
vrm33mvp
vrm33mvp's Avatar
Default 2015 z06??
http://www.worldcarfans.com/11307085...troit---report
Old 07-12-2013, 03:18 PM
LFZ
LFZ's Avatar
How awesome would it be if they kept the same LS7 with the same heads, same guides and valves, and just bumped the hp.
Old 07-12-2013, 03:37 PM
Gary '09 C6
Support Corvetteforum!
Gary '09 C6's Avatar
yeah, does that just mean it'll break faster ?
Old 07-12-2013, 03:50 PM
RedZ4me
RedZ4me's Avatar
That's not nice but keeping it N/A means it won't have a sqweaking blower after a road trip
Kidding
Old 07-12-2013, 03:58 PM
Gary '09 C6
LOL...I just couldn't resist...what with all the valve-drama (sad) et al.
I do love both Corvette Z-cars. The LS7 issues are simply inexcusable IMO.
Old 07-12-2013, 11:50 PM
vrm33mvp
vrm33mvp's Avatar
Old 07-13-2013, 12:00 AM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Well...at least all the parts needed to rebuild a blown LS7 in a C6Z would still be readily available.
Old 07-13-2013, 06:55 AM
Too-Fast
Too-Fast's Avatar
Now this could be interesting, a 600HP LS7 crate motor...with the valve issue addressed, finally, I hope
Old 07-13-2013, 07:01 AM
kenw
kenw's Avatar
Originally Posted by vrm33mvp
too.
Old 07-13-2013, 08:32 AM
DON T.
DON T.'s Avatar
Default Wild dreams
I knew i should not have started Chantix this week to stop smoking. Dr warned me about crazy dreams. AN LS7 powering the new C7! Please......
Old 07-13-2013, 08:51 AM
DaytonaFIC6
DaytonaFIC6's Avatar
If it's a DI LS7 then they would have to use a new cylinder head design. Due to injector placement and the intake ports would need to be raised to clear the fuel rails under intake manifold.
Old 07-14-2013, 08:39 AM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
Originally Posted by Too-Fast
Now this could be interesting, a 600HP LS7 crate motor...with the valve issue addressed, finally......
That was addressed in '11...
Old 07-14-2013, 09:18 AM
z51vett
z51vett's Avatar
Direct injection ls7 would mean new heads also 6/8 operation oh and start stop at red lights thanks all you greenies. Oh I have a 2012 Z06 with 19,400 miles on it 2 years old this Aug. 26 we shall see how the heads play out unless my money ship comes in 69 retired.
z51vett
Doug
Old 07-14-2013, 09:39 AM
8850's Avatar
z51vett
Doug
I have a 2012 too with just over 12K miles. Do you plan to have your valve guides checked? I have not had mine checked.
Old 07-14-2013, 09:59 AM
z51vett
z51vett's Avatar
Not at this time I will buy extend warranty next year and go from there.
They supposedly fixed problem in Feb. 2011 we shall see. Head should have a cast in date as to time and month produced it is most likely under the valve covers. So I can't tell what month mine were produced. I need to find out where this is. Heads are cast ahead of time so this may not be a good indicator. My car was produced in Aug 2011 number 2,226 car produced so very early z06.
Ext warranty prices are under 2000 so the 800 to check will go for extended warranty.
Doug
z51vett
GM retiree
Old 07-14-2013, 10:06 AM
8850's Avatar
They supposedly fixed problem in Feb. 2011 we shall see. Head should have a cast in date as to time and month produced it is most likely under the valve covers. So I can't tell what month mine were produced. I need to find out where this is. Heads are cast ahead of time so this may not be a good indicator. My car was produced in Aug 2012 number 2,226 car produced so very early z06.
Doug
z51vett
GM retiree
Mine was built in November 2011. Were they still making 2012s in Aug 2012?
I might consider an extended warranty but have already put an intake, headers and tuned mine so the 36 month bumper to bumper is all I have left.
Old 07-14-2013, 10:14 AM
z51vett
z51vett's Avatar
Sorry for the confusion sitting here drinking coffee not thinking that is Aug 2011 corrected in my org. post what is the last five of vin that will tell you how many vetts were produced up to that point 427's and zr1's have diff vin numbering. With only 482 z06 produced not many out there.
z51vett
Doug
You can have ext warranty it will fix items not related to the engine I think.
To 2015 z06??
Old 07-14-2013, 11:41 AM
BlueOx
BlueOx's Avatar
Maybe an LT7...with AFM!
Old 07-14-2013, 01:18 PM
8850's Avatar
z51vett
Doug
So mine is about three months newer than yours. Hope GM had both of our valve trains fixed.
My last five are 05642. Doesn't seem to coincide with 482 total made.
Old 07-14-2013, 02:14 PM
SCM_Crash
SCM_Crash's Avatar
I don't think this article is at all right. It would assume that another motor was being built. I don't believe that's the case unless 3 performance trims will be available... again.
The LT1 was obviously designed to ouput more power/torque than it's outputting now. The CAD drawings show a blower on it.
My guess is that - unless there's a 3rd variant they're working - the Z06 will be a blown LT1.
Quick Reply: 2015 z06??
