Mode selector questions and comments
Old 06-01-2013, 07:09 PM
*C7*
*C7*'s Avatar
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default Mode selector questions and comments
Will the car restart in the same mode it was turned off in ?
I would hope it does but they refer to Tour as being the default mode.
It looks like the track mode sets AH and TC to comp mode.
I would guess if you turn active handling off in track mode and restart the car it will go to track mode with AH and TC set back to its default off comp mode.
Any thoughts ??
Old 06-01-2013, 07:11 PM
SCM_Crash
SCM_Crash's Avatar
I'm curious about this too.
Old 06-01-2013, 07:51 PM
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Tour is the default mode that the car will ship from the factory in.
The driver mode is tied to the vehicle memory and will restart where you left it including IP configuration, pocket gauges and subordinate gauges. Those will only change if you change them or if you shift the IP to "Link to Driver Mode" in which case they will change to a predetermined set of gauges displayed for each Driver Mode Selection.
The settings for sport and track will default to their normal settings (ie, track mode with AH disabled.). AH is available and can be turned back on but switching out of Tr (Track mode) and switching back in to Track Mode will return to it's default).
Old 06-01-2013, 08:12 PM
jimmyb
jimmyb's Avatar
Received 4,248 Likes on 2,023 Posts
Paul,
I think (!) I read that AFM will engage only in "Eco" mode, is this correct?
Jimmy
Old 06-01-2013, 08:13 PM
talon90
talon90's Avatar
NCM Ambassador
Originally Posted by jimmyb
Paul,
Jimmy
That is correct.
Old 06-01-2013, 08:22 PM
*C7*
*C7*'s Avatar
If "AH disabled" is the default setting in comp mode prepare yourself for some carnage at the track and on the street!
You heard it here first.
Old 06-01-2013, 08:29 PM
talon90
talon90's Avatar
NCM Ambassador
On the Z51 the eLSD will go a long way toward preventing that carnage. It is an amazing system. As will the PTM system.
Old 06-01-2013, 08:35 PM
*C7*
*C7*'s Avatar
I have high hopes for the eLSD and the rev match. The only thing I'm a little nervous about is the grip of the super sport tires.
Old 06-01-2013, 08:38 PM
sam90lx
sam90lx's Avatar
The tires are good, real good!
talon90
talon90's Avatar
NCM Ambassador
Don't be nervous. Michelin really brought their A game.
Old 06-02-2013, 08:22 AM
Larry/car
Larry/car's Avatar
"Eco" mode? I have driven various rental cars in the last year that have this setting. From experience with these cars, Eco turns a decent car into a dog. The engine hesitates and lacks response (yesteryear you would do a carburetor overhaul with these symptoms), now this dismal performance is programmed into the computor in the guise of economy. They should name this setting on the mode selector "DOG". I could be wrong, I don't think so.
Old 06-02-2013, 08:26 AM
talon90
talon90's Avatar
NCM Ambassador
It is handled a bit better than that in the Stingray.
Old 06-02-2013, 10:35 AM
TRAKCAR
TRAKCAR's Avatar
The settings for sport and track will default to their normal settings (ie, comp mode with AH disabled.). AH is available and can be turned back on but switching out of Tr (Track mode) and switching back in to Track Mode will return to it's default).
That's perfect. Wet track would be Tr with AH enabled if you remember to turn it on, if not the car wound ever interfere, except the edif and abs.
Edif is a game changer. Fingers crossed it will last with heavy track use or bigger aftermarket coolers ASAP.
Old 06-02-2013, 01:33 PM
crabman
crabman's Avatar
Am I missing something here? Comp is really nothing more than a relaxed AH mode. You get to have a little wheelspin, can maintain a little tailout if it isn't too lurid. Its not like the nannies have been kicked to the curb or am I misunderstanding?
Old 06-02-2013, 04:13 PM
SCM_Crash
SCM_Crash's Avatar
I don't think the mode selector turns off the nannies at all. In the C6s, you hold the button down to turn them off. Perhaps in the C7, you hold that middle button down to turn off the nannies.
Old 06-02-2013, 07:07 PM
*C7*
*C7*'s Avatar
I believe I said comp mode when I meant to say track mode.
Talon90 has stated that AH is OFF . in track mode. Not reduced like in comp mode but OFF. We shall see soon enough.
Old 06-02-2013, 07:17 PM
AVETTE
AVETTE's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Default You can be sure...
If Talon90 stated it, since he is giving presentation at Labor Day event in bowling green, that it is a fact.
To Mode selector questions and comments
Old 06-02-2013, 10:13 PM
talon90
talon90's Avatar
NCM Ambassador
You would then be thinking wrong. This isn't a C6.
Old 06-02-2013, 10:46 PM
crabman
crabman's Avatar
You said "The settings for sport and track will default to their normal settings (ie, comp mode with AH disabled.)." which implies that AH is still on but in its comp values, the nannies are still present. In other words by any name this is a relaxed version of active handling just as comp mode is such in the C6 where the nannies are still ready to kick in but at higher values. Or did you mean to say that in sport and track all nannies are turned off, no nannies at all, same as holding the button till you get the off in our C6s?
Old 06-02-2013, 10:57 PM
talon90
talon90's Avatar
NCM Ambassador
In track mode (in a Z51) Active Handling is off. I mistyped in my last post. Where I said comp, I should have typed Track.
The settings as called from the mode selector switch are considerably different than comp mode on the C6. Track mode in the Z51 uses the eLSD and PTM. This is NOT comp mode from the C6. I'm not sure hoe much more plainly I can state this.
Quick Reply: Mode selector questions and comments
