Weight gain in Z51?
Weight gain in Z51?
Compared to the base car please estimate added weight to vehicle with the Z51 package, e.g. Engine oil reserve tank (dry sumped), additional oil hoses and brackets, larger rotors, larger and wider wheels. Please reply with your guesstimate.
Z51 will weigh more than the base car (provided that the two coupes or two convertibles being compared are optioned identically otherwise of course) but I think it will be by less than roughly 40 pounds more total.
Oil tank 8 lbs. related hoses and brackets 8 lbs., brakes 6 lbs., wheels 8 lbs, tires 10 lbs, aero stuff 4 lbs, guesstimate total 44 lbs. equivalent to about 5 gallons of gas, not too bad IMO.
I'm guessing 52 pounds, based on what was posted in the C&D video made in January.
Oh, and gas weighs around 6.25 pounds per gallon, not 8.8 pounds per gallon. You're thinking about the weight of water.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
