A note to GM staff part 2
#61
Good job!
It's difficult to design something iconic and still look exciting. The new C7 is aggressive but carries over a few cues from the past to make it part of the overall lineage.
The engineering looks first rate. The new engine is impressive. 450+ hp and no gas guzzler tax.
Most impressive of all... a very, very modest increase in price with a lot of new features and technology.
I would add that the Corvette team should be very proud of the job they did keeping the C6 generation as great and as profitable as they did. If Tadge and the team had NOT done that, it is very likely there would be NO C7 at all.
#62
#63
#66
Don't be so smug. The LT1 engine is entirely new. If you don't think that engine won't have some teething problems you are naive. The first year of this car will show up things that need to change in the second year of production.
#70
Scraping the splitter.
#71
Couple years later and the valve drop plague has been identified to the heads....at the time I owned it, was still unknown wtf was going on.
#72
Or it could be like the LS2 and LS3, neither of those engines have been as fatally flawed as the LS7....as a former owner of a Z06, I can tell you first hand its a little concerning finding metal pieces (much larger then the normal fuzz) stuck to the magnetic drain plug, I abandoned ship before it was too late.
When Ford designed the 2005 GT they designed the suspension control arms, using a "squash cast" manufacturing process, that were cracking in service. They then redesigned the control arms and replaced the control arms in cars that were sold, after telephoning owners of the GT's sold. The questionable a-arms didn't make the car any less a masterpiece. Ford corrected the problem and moved on.
#73
I find it funny that some are still offended GM hasent said much about this or they will not fix anyting. Cmon , who are you kidding?
Why would they " take care of you" , when we cant even get a good service department from them? Your expecting way to much from GM .
By the way I hate to be negative on a Chevy site but Ford is leaps and bounds ahead of GM in their cars, service and quality. Its not even close.
The only ones that will disagree with me are the " Brand Loyalists" which there is alot of .
#74
Frankly, I don't see much difference between Ford and GM in this regard. They all have their issues good and bad.
#75
In 1968, I purchased a new 1968 VW with A/C(dealer installed VW option). There were two VW dealers in Little Rock, AR at that time. Shortly after, on a 95* day, the car made a large bang from the rear with a huge white cloud of smoke coming from the rear of the car and the A/C started blowing hot air.
I took the car to the dealer near to my home(not the selling dealer) to get it repaired under warranty. I told them to call me if they thought anything was not going to be covered under warrant as the service advisor was questioning the dealer installed A/C.
Sure enough, a couple of hours later , they called and said the warranty would cover the defective A/C compressor clutch, but not pay or the busted hose, the Freon, or the broken belt. I told them to not do anything more to the car and put the parts they had removed in the front trunk.
I picked up the car, drove it to the selling dealer and asked them if the A/C clutch locked up, would everything required to repair the A/C be covered under my VW factory warranty. They said everything was covered 100%.
I picked the car up the next day, with a fully functioning A/C and didn't have to pay a dime. The dealer I originally took the car to wanted over $100(1968 coins) for the items + labor for the items they said were not covered under warranty.
My problem was with the first dealer's service department, not VW. VW paid the second dealer for all the expenses incurred to repair my A/C under warranty.
With my Z06, my problem is with how GM is handling the valve problem, not with how my local dealer is handling the valve problem. My local dealer can not fix the problem unless GM pays them to do so.
#76
You missed my point C5....
If they cant properly run a legit service team , how do you expect them to own up to a huge mistake ?
If they cant put good quality cars on the road , what make you think they will own up to LS7 engine issues.
Yes the service dealer and Gm are completly different but I dont blame those dealers for being the way they are , They just dont know any better, I blame the LACK of GIVING A SHI* from GM , thats made them that way .
By the way there are some good dealers out there just not very many .
Again , if you have to cringe because you have to take car to service , than you know there is a problem . Yes, I cringe anytime I have to take my ride to service. I just thank god its never at all been anything serious.
#77
Another great service review from another satisfied GM owner.
http://forums.corvetteforum.com/c6-c...ealership.html
The good guys at GM! lol
#78
