Sae hp
when I read about 7K rpm vs. 6600 rpm, I begin to wonder about engine life. especially as it relates to getting more than 100K miles out of it (since dropping dead at 100.1K miles wouldn't put a smile on anyone's face) and that pesky thing called a "warranty from GM on the powertrain."
If this chart is real then it's going to be a higher than 6600 rpm red line. 7000 or possibly higher.
That's the same graph that was in the SAE paper discussed a while ago. My thinking is that it is from before the certified testing since it was on the paper written about the design. Additionally all the graphs I've seen from SAE certification have the SAE certified logo. It is likely that the testing produced similar numbers though, so I expect the final numbers to be very close to this.
Some of you guys clearly don't road race or drag race much. You don't want to shift at peak power. You want to shift after peak to maximize area under the curve. For road racing having additional RPM range allows you to extend a gear and not waste time shifting. There are cases where we'd rather let the car bang the limiter at the end of a straight vs. making a shift.
My guess is the 6500 is all marketing misinformation... The car will have 465 horse with a 7000 rpm redline and a massive torque curve.
Remember... the tachometer is electronic... they can make it say 12,000 if they want.
Red line is almost never right at peak HP. It is set just a bit above it so you can rev through peak power to make use of all of it AND get right back into it after shifting. If you set the redline at peak HP then you would end up dropping far below peak power after shifting.
465 would be disappointing, but I'll wait until we get final performance figures before I pass judgment. I really hope the 475 rumor with 7100-RPM redline is true... Yes, 10 hp isn't much, but your hopes have to lie somewhere, heh.
What if it is 465 base, then 475 with NPP? Just a thought as the NPP has 24% more air floe than the C6 NPP.
Regular maintenance is key.
Better, but I was hoping for 480+ with NPP. It just seems like with this significant improvement in tech (higher compression ratio, DI, higher revs), they should be capable of at least a modest 10% improvement.
I guessed 475hp and I think it'll get close.
Scraping the splitter.
You know those clowns do a keyword search everyday to determine in which threads they are going to sh*t.
S.
#33
I just read an article the other day about LS7 development and touched on the amount of effort it took for GM to get the LS7 to 7k RPM. The LT1 does have a shorter stroke and smaller pistons, so it could be a bit easier, but it did take considerable effort, including using expensive titanium connecting rods to get it to spin so quickly.
FWIW, piston speeds on an LS7 are 4700 feet per minute, almost 20% greater compared to the 4000 feet per minute for the LS3, and I assume the LT1.
Given GM already announced the specifications, I am expecting 6600rpm but would be excited to see anything above that.
#36
If increasing HP was their only goal you would easily see more. The Fed's and the increasing standards have a strong influence on the design goals. We can both dislike that (I know I do), but that doesn't change it.
#37
So are these numbers accurate or not? 465 and 448?
#39
Even the old ones.
