SAE testing done...AutoLine After Hours
Old 05-17-2013, 09:55 AM
  #41
sam90lx
sam90lx's Avatar
Originally Posted by RC000E
Spoken like a true sam90lx...misses the whole point...has to say some negative bs...
Read about stretching a gear when road racing then get back to me. Even if it doesnt make power extra rev to work with cuts track times...same as increasing slick size to avoid a shift just before the traps to cut your et...
How is my comment negative? Quit crying like a little baby!
Old 05-17-2013, 10:00 AM
  #42
evilmonkey
evilmonkey's Avatar
Originally Posted by mattkilla2015
So he says it has more power and torque then the bmw 4.4 tt. it would make sense if they tested the lt1 against the one in the m5 (N63B44TU) which makes 439hp and 479tq. Thanks for the link very informative and interesting.
The M5 actually has the S63B44TU 550hp/500tq. I assume he is comparing the LT1 to the N63B44TU 439hp/479tq found in the 550i.
Old 05-17-2013, 10:02 AM
  #43
Mike Mercury
Mike Mercury's Avatar
Originally Posted by sam90lx
You may be able to spin it to 7100 but I bet peak power is done around 6500-6600.
I don't see the negativity this time. Max power is always slightly below redline.
Old 05-17-2013, 10:04 AM
  #44
travisnd
travisnd's Avatar
My guess is the car makes around 450 hp at 6600 rpms, but the real redline is 7000 where it makes 480ish.
Old 05-17-2013, 10:26 AM
  #45
ctusser
ctusser's Avatar
If it revs to 7000 it will be after peak.
Old 05-17-2013, 10:30 AM
  #46
Mike Mercury
THANK-YOU !!!
Old 05-17-2013, 11:39 AM
  #47
eric04
Support Corvetteforum!
eric04's Avatar
the new 4.4 TT makes 460 hp
M5 Sedan
Starting at $90,200 MSRP
22 mpg hwy*
560 horsepower
Old 05-17-2013, 11:42 AM
  #48
mikegaan
mikegaan's Avatar
"More torque at 1,000 RPM than 911 at peak"? That's an eye opener, especially after testing a 2013 C4S yesterday - which was really not bad...different ball park, however, to the 2013 427 1SC I also tried yesterday.
Great post. Didn't know this TV program existed. Do now!
Old 05-17-2013, 11:48 AM
  #49
Kappa
Kappa's Avatar
M5 Sedan
22 mpg hwy*
560 horsepower
That's the S63 engine not N63. GM was comparing to the N63.
Old 05-18-2013, 06:13 PM
  #50
Sullyman
Sullyman's Avatar
Default Found this regarding Jordan Lee's comment about comparison of the LT1 and BMW 4.4 TT
2013 BMW 5 Series Overview
The 2013 BMW 5-Series is available with 4-cylinder 528i, 6-cylinder 535i or V8 550i models, as well as with rear-wheel drive or all-wheel drive. 528I models include a turbocharged four making 240 horsepower and 260 pound-feet of torque, with that peak torque achieved at just 1,250 rpm. The turbo six in 535i models makes 300 horsepower and 300 lb-ft, while the twin-turbocharged V8 in the 550i generates 445 hp and 480 lb-ft.
Given the above listed information regarding BMW's 2013 4.4 liter twin-turbo V8 output and Lee's comment in the interview that LT1 makes more torque and a bit more power is on par with GM's reported estimated 450 hp but what I think is interesting is his comment about making more torque (which was not referred to by Lee as a bit more torque but as more torque) so from that comment I would gather that the torque output of the LT1 is somewhere above 480 lb-ft.
Old 05-18-2013, 08:40 PM
  #51
speedlink
speedlink's Avatar
Originally Posted by BlueOx
LT1 is NOT E85 capable...49:00
I heard that. Wonder if that will stop the E85 whiners?
Old 05-18-2013, 09:18 PM
  #52
SBC_and_a_stick
SBC_and_a_stick's Avatar
Not sure why GM didn't make the 6.2L flex fuel. The gen 5 in all seems to make significantly more power on E85 judging on the 5.3L application:
91/93 oct: 355HP 383TQ
E85: 380HP 416TQ
25hp , 33tq That's huge. If implemented on the lt1, on E85 + 7000rpm redline would certainly be comparable to the LS7.
Old 05-19-2013, 12:33 AM
  #53
mattkilla2015
mattkilla2015's Avatar
Yeah I misread s63/n63 on wiki. The n63 was the engine I was thinking gm compared to the lt1.
Old 05-19-2013, 07:34 PM
  #54
CONMAX
CONMAX's Avatar
part of the reliability testing of all engines includes adding stress. one way of doing this is to run at increased rpm for extended periods. a rev limiter could be raised on sample engines. it would be very time consuming and require huge sample sizes to prove reliability if only nominal conditions were used.
I am not saying that this was what GM was doing when the LT1 was running at 7000 rpm. they may have done this at some other phase of certification than reliability as well. it really doesn't imply anything about peak HP rpm or factory rev limit settings.
Old 05-19-2013, 07:40 PM
  #55
BlueOx
BlueOx's Avatar
I would think that if it couldn't/wouldn't/shouldn't somehow reach 7k in some mode, they wouldn't let ANYONE suggest that it could. I sure wouldn't think Kirk Bennion would be mentioning it at all.
Old 05-19-2013, 07:46 PM
  #56
DREAMERAK
DREAMERAK's Avatar
St. Jude Donor '12-'13-'14, '16
E85: 380HP 416TQ
Maybe they are saving it for a later date?
Old 05-20-2013, 02:06 AM
  #57
Michael A
Michael A's Avatar
Received 2,919 Likes on 1,361 Posts
Originally Posted by Jawnathin
Yup. I like having the additional gearing whenever possible, one of my favorite things about the LS7.
In addition to stretching a gear, its possible for the manufacturer to use a shorter gear instead and get to the same MPH as a taller gear, allowing a better mechanical advantage in putting power to the ground.
And lets not forget, the more revs, the better it sounds!
There is a lot to like with 7000rpm.
Absolutely! Image the redline of the Ford 5.0 DOHC V8, with the torque of the 6.2L LT1.
Michael
To SAE testing done...AutoLine After Hours
Old 05-20-2013, 12:31 PM
  #58
LT1_E85_Corvette
LT1_E85_Corvette's Avatar
E85: 380HP 416TQ
To my point earlier... They know the engine can run on E85 but it would threaten Z06 owners if they did. They are just protecting their prized car which I think is a little crazy suggesting it would only help sell the car to younger buyers. Younger people LOVE E85
Old 05-20-2013, 01:29 PM
  #59
NemesisC5
NemesisC5's Avatar
The previews of the reconfigurable instrumentation show a 6600 rpm redline in every mode including race. This could be part of a cover up regarding redline capability of the LT1 or it may not be. I myself hope that the LT1 has the 7k rpm capability regardless of where peak power is made, IMHO the extra revs make for a more exciting driving experience and race inspired exhaust note. Just my $.02
Old 05-20-2013, 05:03 PM
  #60
speedlink
speedlink's Avatar
Too much effort to make it happen at this time and given how little availability of E85 there is.
Please, please, keep it that way! Or take it away entirely. What a waste of oil.
Quick Reply: SAE testing done...AutoLine After Hours
