Go Back   Corvette Forum > C7 Corvette > C7 General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C7 Corvette Discussion not covered in Tech Sponsored by
Kerbeck Corvettes
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-08-2013, 11:34 AM   #1
Halltech
Supporting Vendor
St. Jude Donor '09
Halltech's Avatar
Halltechsystemsllc
Default 1.47 HP/Cubic Inch
I predicted 490 HP a number of months ago. Maybe GM knows something I don't know about math.
Think about this. The 2012 Chevrolet Camaro LFX V6 Engine is rated at 323 Horsepower. Direct Injection rules!! http://gmauthority.com/blog/2011/04/...23-horsepower/
The LT1 will be 6.2 liters or 72.22% more displacement that the mini 6 cylinder Camaro. Do the math.
Oh, and the Camaro Z28 will be horsepower king at 505+ HP? Right. If that happens, GM will never live it down. Obviously a Supercharged ZL1 will trump the LT1, but I do not believe for one minute the Camaro all motor 427 will.
If you do the math based on the DOHC mini 6 cylinder hp/ci, the interpolation for the LT1 would be 556 HP.
Jim Hall
Halltech is offline   Reply With Quote
Old 05-08-2013, 11:49 AM   #2
Dominic Toretto
CF Senior Member
Dominic Toretto's Avatar
Send a message via MSN to Dominic Toretto
Correct me if I am wrong but, hasn't GM had Camaros that were momentarily more powerful than Corvettes before?
-Alex
Dominic Toretto is offline   Reply With Quote
Old 05-08-2013, 11:50 AM   #3
1985 Corvette
CF Senior Member
1985 Corvette's Avatar
Send a message via AIM to 1985 Corvette
I think the power figure will be below 500 for the LT1. I have no qualms about the Z28 having superior power figures. They are both Chevrolets but the entry level Camaro is a 6 cylinder offering. So a hard egded Camaro a couple of rungs up on the Camaro ladder edging out the entry level Corvette isn't so bad. Interesting predictions though! I will enjoy seeing how close you are.
1985 Corvette is offline   Reply With Quote
Old 05-08-2013, 11:53 AM   #4
Halltech
Supporting Vendor
St. Jude Donor '09
Halltech's Avatar
Halltechsystemsllc
So you think that the 3.6 liter 6 cylinder motor will have more power/cubic inch than the LT1?
Explain please.
Forget the Camaro stuff for a moment. That is just a marketing thing, and you could be right about that. The weight/power will go to the Corvette for sure.
The only advantage the 3.6 L 219.7 cubic inch Camaro motor has over the LT1 is overhead cams. Chevy has already proven that they can squeeze as much hp out of the pushrod motors as ohc.
Old 05-08-2013, 11:55 AM   #5
WaxWeekly
CF Senior Member
WaxWeekly's Avatar
Send a message via AIM to WaxWeekly
We know they're holding something back. Not just peak HP, (which really isn't THAT important other than marketing) but it's slipped that the new motor power curve stays fairly high over 7000 RPM. Peak power is cool and all, but a motor that climbs smooth and stays high over 3000 RPMS, sustaining its peak power through ~1000 RPMs is just plain nuts.
I'm really looking forward for the real reveal on the performance specs. All we've gotten so far is little marketing crumbs. It could very well be 500+, but it could also be something different across the RPM range.
WaxWeekly is offline   Reply With Quote
Old 05-08-2013, 11:57 AM   #6
Daekwan06
CF Senior Member
Daekwan06's Avatar
Daekwan Daekwan Daekwan Daekwan
I'm sticking with 475. As I said earlier it accomplishes everything GM needs it to:
1) 475hp makes the base C7 significantly faster than both the base C6 & GrandSport C6.
2) 475hp makes the C7Z51 "competitive" with the outgoing C6Z06.
3) 475hp leaves plenty of room for HP increases in future model years of the base C7.
4) 475hp leaves plenty of room for a 550-600hp C7Z06 427ci, should GM decide to bring LT1 upgrades to the LS7 engine.
Daekwan06 is offline   Reply With Quote
Old 05-08-2013, 12:00 PM   #7
Halltech
Supporting Vendor
St. Jude Donor '09
Halltech's Avatar
Halltechsystemsllc
One more way to look at it. Lets say you add two more cylinders to the 3.6L 6 making it a 4.8 liter V-8, with exactly the same cylinder configuration, timing, valve gear, etc. That would be a 440 HP motor. 292.9 cubic inches and 440HP!
Old 05-08-2013, 12:03 PM   #8
BuckyThreadkiller
Successful Plumber
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
Support Corvetteforum!
BuckyThreadkiller's Avatar
Location: Top of the hill, 3rd mailbox on the right. Texas
That motor actually makes the V6 Camaro a fairly attractive package. I had an LT1 C4 with 10% less hp and it didn't get nearly the 30mpg they are claiming for the LFX in the Camaro.
BuckyThreadkiller is offline   Reply With Quote
Old 05-08-2013, 12:04 PM   #9
BlueOx
CF Senior Member
BlueOx's Avatar
Jim Hall
I can easily believe that GM knows more than you about math, how to produce horsepower and whether/which Vette will be the hp king or not. They also know a whole lot more than you about what matters to them in the scheme of things and what the future will be bringing.
BlueOx is offline   Reply With Quote
Old 05-08-2013, 12:07 PM   #10
Dominic Toretto
CF Senior Member
The F22C has more power per cubic inch than any LS/LT motor at 1.77. 238hp/134.3ci. So what? Doesn't mean that engine is better. I've got a buddy at work with that car and he always totes how much power it makes from such a small displacement. He never raced me when I had the C5, after getting my 2012 5.0, we ran from a 40 roll and left him by several car lengths. My car bone stock and he has headers, exhaust, intake, a manual transmission, lighter wheels etc.
Not to get off on a separate tangent but point I am intending to make is that so what if it has a better power/displacement if it is still a slower car and still makes far less power. 323hp is still much less than an LS2 lol. Just sayin.
-Alex
Old 05-08-2013, 12:14 PM   #11
Halltech
Supporting Vendor
St. Jude Donor '09
Halltech's Avatar
Halltechsystemsllc
Just speculation, which is what I am doing. I have only the current technology to base my assumptions on. If GM cannot match the 1.47 HP/cubic inch of a base car Camaro, what exactly will they do to reduce horsepower to around 1.25 hp/cubic inch ?
I'm not saying you are not correct, but I think you assumptions are.
The 427 platform is gone as far as the Corvette is concerned. Direct injection is here to stay, and the next motor will not be a 427.
We are in aftermarket intake sales, so if the intake is very restrictive, you might see a substantial loss of power, making our job real easy and profitable.
We should see pretty soon.
Old 05-08-2013, 12:15 PM   #12
Daekwan06
CF Senior Member
Daekwan06's Avatar
Quote:
Not only that. The Camaro starts at $24,000.
You want something brand new, thats sporty, looks great, gets 30mpg, has backseat & trunk and comes with decent all around performance. The Camaro is still about the best buy I can think of in that price range.
I like the Mustang too.. but the base V6 version is still too feminine for me.
Old 05-08-2013, 12:16 PM   #13
vankenn
CF Senior Member
Power is about displacement and compression. Anyone can make a powerful engine. It's the one that can make it run efficiently that wins. Who cares about a 500 or 1000hp engine that run 6-10 miles a gallon. If u can get a 500hp engine with 30-40mpg, I'm golden
vankenn is offline   Reply With Quote
Old 05-08-2013, 12:19 PM   #14
1985 Corvette
CF Senior Member
Explain please.
I am by no means an expert on the subject, but I don't believe it would be unheard of if the Camaro wins this power/cubic inch comparison. How about 8.3 liters or 7 liters for "just" 500 hp? Not knocking it but the power delivery will be worlds apart, even if the V6 is superior in that respect of power output per cubic inch displacement.
The DOHC plays a huge role in the V6 being able to achieve its power.....I was already impressed with 305 out of the motor years ago. I would REALLY like to see a return to DOHC in the Vette, I feel the displacement allows plenty of down low fun while the extra valves allow lots of breathing up top to keep pulling.
I would not rule the 427 out. R&D has come a long way since the LS7 was produced. There is simply too much marketing goodness and gimmicks to pass up by never bringing it back. Remember when Dave Hill said using 7 liters was never intended as a marketing ploy? Who really bought that line?
Old 05-08-2013, 12:26 PM   #15
Daekwan06
CF Senior Member
Daekwan06's Avatar
Trust I'm hoping you are right.. and I am wrong.
The C7 is already an absolute buy for me. 490hp just makes that more absolute-er
Old 05-08-2013, 12:30 PM   #16
vankenn
CF Senior Member
You can easily increase hp without forced induction by changing the crankshaft, pistons, for higher compression, intake, exhaust for increased and better airflow. If u really wanted too, I'm sure u can push 500-550 easily on the stock engine. But how long will that last before it blows up? Running it softer is better for the engine and thus the manufacturer can provide u with 100k, 5 yr power train warranty.
Old 05-08-2013, 12:30 PM   #17
lt4obsesses
CF Senior Member
lt4obsesses's Avatar
The only problem I see with the math is that is assuming a linear increase in power/cu. in. In the equation, there should probably be adjustments made for increased mass of rotating assembly and bigger, heavier parts, pistons valves, crank etc. I'm no math major, nor engineer, but I would guess that for every increase in displacement, there is a subsequent increase in mass for the parts involved, which would lower the HP/Cu. in. ratio?
lt4obsesses is offline   Reply With Quote
Old 05-08-2013, 12:34 PM   #18
vankenn
CF Senior Member
Quote:
Not necessary true. U can use forged internals or other material and lighter parts to reduce weights.
I'm an engineer myself and have experience building engines and transmissions
Old 05-08-2013, 12:34 PM   #19
flange
CF Senior Member
me thinks the horsepower may be a lower advertised number than everyone wants ot see, based upon the fed govt wanting it that way. wouldnt be the first time it happened.
flange is offline   Reply With Quote
Old 05-08-2013, 12:36 PM   #20
Dominic Toretto
CF Senior Member
Comparing a 300hp V6 Camaro to a near 500hp V8 Corvette engine is pretty interesting.
-Alex
Reload this Page 1.47 HP/Cubic Inch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
