1.47 HP/Cubic Inch
I never understood this fascination with displacement to horsepower ratios that people tout. To me, the external dimensions of an engine are much more important, than the internal dimensions, as a more compact design allows for more versatility on the overall car's design. Those DOHC engines tend to be more complex, wider, and more expensive than their pushrod brethren. Also GM tends to over build the engines IMO. 300rwhp LS1's that are capable of 700rwhp on stock internals. Not too shabby.
They also don't understand that our engines are actually Lighter than their's. It's always funny hearing GTR fans talk about how "Gm can't even hit 100 horsepower per liter... and the GTR is well past it!", without realizing our engines are 70lbs or more lighter. (LS9 vs GTR)
No way its linear.
I predicted 490 HP a number of months ago. Maybe GM knows something I don't know about math.
Think about this. The 2012 Chevrolet Camaro LFX V6 Engine is rated at 323 Horsepower. Direct Injection rules!! http://gmauthority.com/blog/2011/04/...23-horsepower/
The LT1 will be 6.2 liters or 72.22% more displacement that the mini 6 cylinder Camaro. Do the math.
Oh, and the Camaro Z28 will be horsepower king at 505+ HP? Right. If that happens, GM will never live it down. Obviously a Supercharged ZL1 will trump the LT1, but I do not believe for one minute the Camaro all motor 427 will.
If you do the math based on the DOHC mini 6 cylinder hp/ci, the interpolation for the LT1 would be 556 HP.
Jim Hall
Jim Hall
This engine should easily break 500 hp ,but it wont for marketing reasons.
It makes sense ,from GM's perspective to detune it initially,so that in year 3 they can bump the power up 25-30 hp with minimal effort.
As for the Camaro being horsepower king...who cares?.....It wont affect C7 sales.....Totally different market segment.
I would have bought a 500hp coupe, but now I have to wait for a higher hp model and pay way more money for it because they chose to sandbag so badly on this engine.
Wasn't this thread posted before?
It's simple to see that DOHC motors with 4 valves per cylinder can flow more at the same lift. The same hp/liter would apply only to a bench racer.
There is really nothing to talk about here. /thread
Jim Hall
Jim Hall
Unfortunately GM is too dumb to actually make the car with even 500hp from the factory. This WILL hurt sales quickly on the car once the early adopters get their units filled.
My 1200 CC ZX12 Kawasaki motorcycle makes 2.6 hp per cubic inch, that does not mean that Chevy should be able to build a 977 HP small block. Volume increases on a logrithmic scale, not linear. Limits such as piston speed also prevent larger engines from achieving the RPM that smaller engines can reliably attain. The initial premise of this thread is flawed.
For the base model Stingray, GM seems to have been more concerned with a flat power curve than total horsepower figures. For most people it will make the car feel more powerful since many seldom do redline shifts. All that being said, I would not be surprised if there is quite a bit of power left on the table to help future sales. Once more data is in obtained about the engine, they can bring in more horsepower and be confident that it will still be reliable.
#33
I'm more talking about the engines as they are built, not so much as they could be built. These are both engines that have to deliver reliability, durability, and maintain a profit margin, considering that they are subject to a 100,000 mile powertrain warranty. That said, they could very well make the LT1 a 700hp monster if they wanted, they just don't want to, at least not yet.
#34
6.2L Mercedes engine has 622 horsepower. So why doesn't the GM 6.2L LS3 or LT1 have 622 horsepower? They are both normally aspirated and have the same displacement and both have VVT and DI.
It's more than just HP/L that determines how an engine is designed and for what application..
#35
Received 2,043 Likes
Agreed a smaller engine is easier to make more efficient as it doesn't require as much air.
#36
The 505hp camaro still will not be faster than the base c7...
#37
Supporting Vendor
St. Jude Donor '09
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
#38
Not my field of expertise in engineering, but it seems that there are so many different variables, no way a linear relationship would apply. Lots of thermal characteristic differences. When you start looking at areas vs outside circumferences in relation to cooling, flame face temperature gradients, etc, lots of differences that would affect efficiencies.
#40
Does no one here realize that a 3 liter motor revving to 10k rpm is the same total displacement as a 6 liter revving to 5k? The fact is that efficiency has not been significantly improved in decades. We still only get 25-30% of the power out of the fuel. That's why those more "efficient" high revving, high hp, low displacement motors STILL don't get any better mileage than a Corvette. All these different engine designs just make it possible to burn more or less of it in a given amount of time but in the end, they produce about the same power.
I would like to see the manufacturers start posting hp/lbs not hp/liter. Unfortunately they make it hard to find accurate weight and external volume measurements. Would you guys complain if GM had a motor that had pushrods with one valve per cylinder that made 500hp if it was the size of a shoebox? THAT should be the goal here, not hp per liter.
