C7 Non-ZR51 Coupe Width
Published specs states width w/o mirrors is 72.9 inches. Can someone provide width with mirrors? I have a small garage door width to deal with.
I don't have an answer on the width, but I imagine you should be ok. I don't remember seeing a standard garage door smaller than 8' wide. I've got a pair of those on my garage and as long as I hit it straight in, I never had a problem with the C5...
C5 published specs states width w/o mirrors is 73.6 inches. Garage door is 8 footer; still believe I'm OK?
Probably the same as the C6 which is ~82 5/8" across the mirrors. I park my Z06 under one of my 4-post lifts that has 92 1/2" distance between the posts. When I change the oil I drive it on the lift with 90" between the cables.
E-Ray, 3LZ, ZER, LIFT
Received 9,622 Likes
Hate to think I have to get out and tuck the mirrors in by hand when it’s dark!!
