Lifting a C7............
Old 05-05-2013, 11:22 AM
R&L's C6
Support Corvetteforum!
R&L's C6's Avatar
Received 1,254 Likes on 708 Posts
Default Lifting a C7............
I don't know if this has been talked about yet, but I wonder if the C7 will suffer the same fate at the dealers as the C6....cracked rockers. Does anyone know if jacking pucks will be needed on the C7?
Old 05-05-2013, 11:25 AM
sam90lx
sam90lx's Avatar
They are already lifted, have'nt you seen the fender gap?
Old 05-05-2013, 12:01 PM
gthal
gthal's Avatar
Received 1,170 Likes on 486 Posts
Way to go with a meaningful and completely untroll like response
Old 05-05-2013, 12:09 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Hey Randy,
They will lift similar to the C6/Z06 and yes, if not done properly will suffer the same fate as the C6.
Old 05-05-2013, 12:35 PM
-CM-
-CM-'s Avatar
Originally Posted by talon90
Hey Randy,
Do you think the jacking pucks I currently have on my C6 will work with the C7?
Old 05-05-2013, 02:01 PM
talon90
talon90's Avatar
NCM Ambassador
What type of jacking pucks do you currently have?
Old 05-05-2013, 02:12 PM
R&L's C6
R&L's C6's Avatar
Hey Randy,
Thanks, Paul
So it's just a matter of time before we get the first "dealer cracked my rockers" thread in the C7 section...
Old 05-05-2013, 02:29 PM
-CM-
-CM-'s Avatar
These from Southern Car Parts.
Old 05-05-2013, 02:31 PM
talon90
talon90's Avatar
NCM Ambassador
Those should work just fine.
Old 05-05-2013, 04:37 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,129 Likes on 6,195 Posts
Paul, will the Elite Engineering pucks work on the C7?
Old 05-05-2013, 04:47 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
You can't use pucks that say "C5" on them on a C7 even if they do fit!
Old 05-05-2013, 05:44 PM
DREAMERAK
DREAMERAK's Avatar
St. Jude Donor '12-'13-'14, '16
This is true...
Old 05-05-2013, 05:52 PM
AmmoVet
AmmoVet's Avatar
Those are BMW pucks, I picked up mine from a BMW Parts Counter and have had them permenantly installed since 2006. total cost was around $30 if I remember correctly.
Old 05-05-2013, 06:42 PM
Zymurgy
Moderator
Zymurgy's Avatar
Originally Posted by DREAMERAK
This is true...
The ones that I have actually have "C6" on them, so they'll only be one generation off.
Old 05-05-2013, 06:47 PM
SCM_Crash
SCM_Crash's Avatar
I would imagine the C7 will be harder to lift from the back. On the C5s I put a piece of wood across the cradle beams in the back and lift from the wood. But I suspect that the C7 is going to be completely different back there.
I'm just glad I won't be doing any work on it for a few years.
To Lifting a C7............
Quick Reply: Lifting a C7............
