Michelin Tire update
Old 04-30-2013, 09:40 PM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default Michelin Tire update
Here are the current C7 tires.....should be something there for near everyone
Old 04-30-2013, 09:47 PM
Michael A
Michael A's Avatar
Received 2,902 Likes on 1,354 Posts
It's funny they are calling the 2014 a Grand Sport, rather than Z51.
Michael
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
hmm, looks like I see my next set.
There is one thing I don't understand, however. The sizes for a standard C6 and a standard C7 are the same. And so are the parts numbers for the Super Sports ZP (69693). But the specs call for a different UTQG speed and load rating (ex. 88Y for front on C6; 93Y for front C7). Wonder how they do that----presume the tire is built to the 93Y spec, and will suffice for the lesser, 88Y spec.
Old 04-30-2013, 10:13 PM
-CM-
-CM-'s Avatar
What does the ZP column indicate?
Old 04-30-2013, 10:28 PM
Smoltz
Smoltz's Avatar
Zero Pressure aka Runflat
Old 04-30-2013, 10:32 PM
waynelittle1
waynelittle1's Avatar
Nope. Even though the C6 GS outsells the coupe, we get f'ed on the newest Michelin technology....still no A/S, A/S ZP, etc
Old 04-30-2013, 10:43 PM
aseipos
aseipos's Avatar
Looks that way, doesn't it? Lee Willard at the Bash presentation made some comment about the new tire possbily becoming available in C6/Z06/GS sizes, but no promises.
Old 04-30-2013, 10:46 PM
sam90lx
sam90lx's Avatar
Love my PSS non run flats, awesome tire!
Old 05-01-2013, 12:28 AM
Gary '09 C6
Gary '09 C6's Avatar
interesting that there's also no PS2 ZP for the C7 w/Z51 ("grandsport" in the chart above).
Old 05-01-2013, 12:55 AM
X25
Sr.Random input generator
X25's Avatar
Received 1,463 Likes on 1,020 Posts
Well, there is PSS; no need for the PS2, which is being replaced by PSS anyway.
Old 05-01-2013, 03:09 AM
B747VET
B747VET's Avatar
As Ozer said above, PS2 is being replace by the PSS. PSS grips better, costs less, is quieter, and lasts longer, up to 18% longer.
Strong ditto
Old 05-01-2013, 07:58 AM
-CM-
-CM-'s Avatar
I hope they come out with an A/S ZP choice for the Z51 sizes.
Old 05-01-2013, 06:48 PM
Cruise-In V Veteran
NCM Ambassador
This is the first round of sizes.............so more may come
Old 05-01-2013, 09:37 PM
Gary '09 C6
Originally Posted by B747VET
As Ozer said above, PS2 is being replace by the PSS. PSS grips better, costs less, is quieter, and lasts longer, up to 18% longer...
that's in the C6 non-runflat version, I presume. Any comparable data yet for the C7 PSS run-flat version ?
I do suspect the results will be similar...and thanks for the info.
Old 05-01-2013, 10:07 PM
X25
X25's Avatar
Why would you think PS2 would be similar to PSS? Because it comes with ZR1? PS2 is more than a decade-old tire. It used to be one of the best when it was introduced, but not much so these days. The new PS2 sizes and ZP version introduced later are not much different than the original tire in terms of traction, either. PSS is introduced in 2011, and provides better wet/dry traction while providing longer life. PSS ZP will not be hampered much by the run-flat add-on since the new run-flat tires only add about 1 lb to the overall weight, and new tire designs use the hard sidewall design that comes with the ZP tires for handling advantage anyway.
I would love to have PSS ZP in Z06 19"/20" sizes; one could only hope
Old 05-01-2013, 11:05 PM
Gary '09 C6
I was referring to (asking about) the performance of the PSS in the new run-flat version, not the PS2.
Many here have commented quite favorably on the PSS tires, but so far the same are non-run flats.
there could be a difference in PSS performance between the two versions, but I certainly do not know.
Old 05-02-2013, 06:40 PM
Cruise-In V Veteran
NCM Ambassador
I hope to test soon and give you an answer
Since I have been in a 2012 ZR1 with Tommy Milner punishing them for a few laps at WOT........the ZP and the design was derived from a combination of technologies found on the MICHELIN Pilot® Sport Cup ZP tire that helped the 2012 Corvette ZR1 post a 7:19.6 Nürburgring lap time with significant gains from the development of the MICHELIN Pilot Super Sport tire..........it will be a sticky ****
To Michelin Tire update
Old 05-02-2013, 07:36 PM
johnglenntwo
johnglenntwo's Avatar
Default Remember!
The cars weight is now biased differently so putting these tires on the older Vettes probably won't yield like results.
Old 05-02-2013, 08:57 PM
X25
X25's Avatar
I don't get it; why would it be different? Both C6 and C7 have about 50/50 weight balance.
Old 05-02-2013, 09:21 PM
Gary '09 C6
very and thx...looking forward to the info !
Quick Reply: Michelin Tire update
