Sandbagging on HP...MAYBE
#41
AIR FORCE VETERAN
I have driven many LS3 engined cars. Plenty of horsepower , loads of torque, and fun to drive. Now if my new C7 has the same amount of power as an LS3 I will always be a happy camper. If it has more that is fine but not necessary for me to be happy with my Corvette.
#42
Hey Dan;The engine you're referring to was RPO ZL1, an aluminum block 427 offered during the '69 model year only. The cost was $4718 (base price on a '68 coupe was just $4781) and only two were built. Factory rating was 430 hp but the actual number was much higher. More like around 550.
#43
http://www.thel88corvette.com/
http://www.supercars.net/cars/349.html
http://corvettes.about.com/od/histor...te-L88-427.htm
#44
The story I understand is that the L88 was grossly under rated on the order form for sole purpose of discouraging the general public from ordering it. The engine was built for racing applications, forget which series they said, but the class had to use a 'factory' engine. The story I read was that it was fairly close to 600hp.
If GM had chosen to "see" the peak horsepower on that same L-88 dyno graph, it would have been much higher than 430 HP at 5800 RPM.
#46
07 GT500 was advertised as 480 hp it was certified at 500 hp...ZR1 was supposed to be 620 hp then certified to 638 hp...013 GT500 was 640 but it was certified at 662 hp so I have no doubt the advertised 450 hp C7 will be in the 470 plus hp area.
#47
It's only speculation, but I wouldn't be surprised if the SAE rating is the same as the publicly released estimated numbers, 450 HP/TQ. They probably have had the numbers dialed in for some time but elected not to release it.
#51
40-50 years ago, the marketing department published HP numbers that sounded good rather than based on fact. Also, there was the Gross vs. Net ratings that came into play in 1972. But that was 4 generations of Corvettes back and this is the C7 forum. So if you want to post stuff about HP ratings back then, go to the C3 forum.
Manufacturers can't play games with the ratings today. It will be published based on estabilished SAE rating method.
#53
#54
I think 475 will be the final number. It accomplishes everything it needs to do. It guarantees the C7 base will be significantly faster than the C6 base.
And 475 approaches C6Z06 "competitive" territory.. while still leaving plenty of room for a 525+hp C7Z06 and 650+hp C7ZR1.
#55
GM will most likely sandbag the HP ratings a bit. Then as always during the mid cycle re-fresh they will bump up the HP.
I don't really understand all of this worry about the "numbers". Just sit back and wait... I
The numbers that I really can't wait to see, is what happens when some of the tuners like England Green, Cartek, Vette DR's. Get these LT1 engines and see what real numbers they can put down.
#57
Sandbagging...
http://www.youtube.com/watch?v=8uMp-PTAfCE
#58
#60
