Showcasing E85?
#41
Taking a MPG hit!
If the MPG rating would have to take a hit (obviously if they averaged the E85 MPG and E10 MPG together it would) then that alone would blow the idea out of the water as it is delivered out the door.
Maybe they are saving it for the supercharged model? The EPA probably wouldn't even noticed the MPG difference there!
#42
Ethanol ruins more engines. As far as refinery's, I do not want to subsidize your state or any other state, in order to make gas that is more expensive, more corrosive, and yields less mileage. Makes no sense. At the same time takes a food supply away. This is wrong on just about every level.
If you want to use it for racing, refine yourself, but don't ask me to pay for junk!
And no, the corn they use for E85/75 is not food-grade corn. It does NOT take away from our food supply. That's another stupid myth. You really think they'd spend a LOT of money growing healthy-to-eat corn just to turn it into fuel? LOL If you do, you're very naive.
#43
Ethanol doesn't ruin engines. Who ever told you that is wrong. There's no documented case where E85 has ruined an engine. In fact, the complete opposite was found to be true. Alcohol actually cleans the engines and has a cooler cleaner burn. There's been MANY ethanol tear-downs and the engine ALWAYS looked better than their E10 and E0 counterparts.
Then on the food side....really confused here. while I agree that there is some corn that goes directly to your dinner table via frozen or canned corn, doesn't the rest of the corn get used to make sweeteners and such? I think that the second type of corn is in fact the same stuff used for ethanol. Living in Nebraska I am surrounded by corn and only know of three main types(yes I do realize there are tons of hybrids and such); sweet(frozen and canned) white(mostly for food) and the most common yellow that is used to make sweeteners, animal feed and ethanol. feel free to correct me if I'm wrong, but that is my understanding.
I know that ethanol has had a impact on the price to feed livestock so I find it hard to believe that ethanol is made from an entirely different corn type. If it is, then it is displacing the food grade corn in the fields, and thus having an impact on food supply.
Other comments on ethanol...and remember that this is coming from someone running E85 in their twin engine front engine dragster(see photos). In a performance application, I love it. You really must keep an eye on system maintainance if trying to use in older carbs/pumps. But otherwise it runs really cool and clean.
One thing that no one really talks about too much is that you need almost twice the fuel volume in comparison to gas so any performance gains are somewhat offset by increased cost.
#44
Not being difficult, just wanting to know your opinion on the difficulty lawn mowers have with ethanol fuels. I had one die and I suspect it was the ethanol blend fuel I had been using. Just did a search and plenty of sites popped up citing the damage it can cause and to stay away from it.
As for the engines and lawn mowers... Most of those were not built with stainless fuel lines. There's a ton of rubber in older lawn mowers. Especially push-type. Of course they're going to have problems. BUT, that's not because of the Ethanol. That's because of the fuel lines getting eaten up. Since 1990, auto manufacturers have used stainless fuel lines so that this doesn't happen. Alcohol itself does NOT hurt the car. In fact, those fuel injection cleaners are alcohol based.
BTW, whenever an older car has shown damage from ethanol blends, the damage was NEVER from the alcohol in the engine. The damage was from components outside the engine that were not ethanol ready. Older cars can simply upgrade their fuel pump, carb/injectors and fuel lines and they'll run E85 without risk of damage (as long as they're tuned correctly).
There's a lot of hoopla about Alcohol being corrosive because people aren't completely reading what is actually happening. They're reading a few key words in articles and what-not about what E85 does. This is how misinformation gets spread around. People in other regions of the world that have access to E85 run on LSx platforms do all the time. I remember there was a guy in NL that was running E85 in his LS1 Trans Am. No problems whatsoever and he was even running cat-less. He said it smelled like pop-corn. LOL
It's a scare tactic. Believe me.
BTW, the car I learned how to drive on in 1999, a 1985 Corvette, had NO problems running on E10 for every single year it was around after 1990. NO issues. It's just malarky. People who have engine troubles like to blame anyone but themselves.
#45
So those three types of corn you're talking about are all food-grade corn. They're all grown for consumption. That means that the pesticides, seeds and soils must be food-grade products. Either way, it's far more expensive to use live-stock feed and/or human-bound corn for Ethanol.
I don't get your reference to the pesticides soil comment.....you are losing me.
I do agree that there may be cheaper ways to make ethanol that are better for the end cost of consumers of both food and fuel.
Bottom line is ethanol has a place in cars that are designed for it.
#46
http://www.corvetteracing.com/histor...detroit1.shtml
It is avenue to a cooler running more powerful cars and you hate it? Politics? Do guys like you work for Exon or something? The ZR1 can heat soak at 638hp. Simply adding E85 could AUTOMATICALLY get it up to 680hp without the heat soak. Give me a Fricken Break!
#47
So now I'm confused on your stance....does it take from our food supply or not?
One experience that opened my eyes on E-10 a bit comes from when a car that came into a dealer I used to work at. The car was not running well..no power, would barely stay running. We tested the alcohol percent and it was over 80%......he bought E10. Are the current blends formulated to stop this from happening?
What I meant about the soil and pesticides is that when you have food slated for consumption, the soil and water the food grows from, and pesticides that protect the food from being eaten by bugs has to be safe to "us". Whereas, you can use lower grade water and soil and cheaper pesticides to grow plants slated for combustion, rather than ingestion. That makes things far cheaper. There's different grades of food out there. Lowest grade (less or unhealthy) food still makes alcohol. (That's the point)
The whole idea that E10 causes engine troubles has been debunked for 30 years. California has been 100% E10 for 30 years and our cars aren't having problems due to E10. Sorry, but anyone who tells you otherwise is simply lying or got their information wrong as well. My 1990 300zx wasn't even built to handle E10 and it ran like a champ on it. My 1979 Bonneville NEVER had any trouble running on it. We had that car since it was new until 2002. NEVER had any trouble and that car was DEFINITELY not meant for E10. With 460K miles on the original engine, we finally retired after I bought my 1997 Trans Am. That LT1 ran like a champ on E10 as well. No issues whatsoever. Then I bought a 2002 Trans Am and guess what... no issues. Same with my 02 Z06 and 03 Z06.
If there was actually a problem with E10, there'd be a mass class-action lawsuit against the state of California for hurting our cars with E10.
#48
More!
Again, it can be made from: American Le Mans Series Ferraris switch to cellulosic E85
Another advantage is a highly effective octane rating, reducing engine heat and wear, and increasing engine performance if an engine is tuned to run on E85, or able to automatically adjust to higher octane fuel.
Using E85 in a gasoline engine has the drawback of achieving lower fuel economy, as more fuel is needed per unit air (stoichiometric ratio) to run the engine in comparison with gasoline. The additional ethanol required for a stoichiometric fuel ratio helps compensate for lack of energy provided by ethanol's lower heating value (LHV), which is lower than the LHV of gasoline.
http://en.wikipedia.org/wiki/E85
#49
The ethanol source is mixed at the moment. We get a lot of our ethanol from Brazil. That means it's NOT coming from our food supply. The ethanol we don't import isn't supposed to come from our food supply. I have no evidence to support that statement though. And "farmers" are hiking up the prices on corn because they can state that it costs them more to have to grow more. There's no evidence of that either. Hiking up the price on corn was something they always wanted to do and the farmers' statements were debunked many years ago. That's why the cost of corn dropped again. They were looking for an excuse. You don't see them refusing to grow it and sell it for ethanol, do you?
http://cornandsoybeandigest.com/ener...nol-and-brazil
http://www.greentechmedia.com/articl...ff-on-ethanol/
http://www.motherjones.com/kevin-dru...der-we-thought
http://ethanolproducer.com/articles/...thanol-imports
http://oilprice.com/Alternative-Ener...d-Ethanol.html
#50
Interesting read on "importing" ethanol from Brazil.
#51
You have some bad info there.
The LT1 is the GenV engine used in the C7 Corvette and we all know that it is a E0/E10 engine designed for 91 octane.
The three GenV engines used in the 14 Silverado are the LV3(V6 with 11: CR for 87 octane), the L83 V8 with 11:1 CR designed for 87 octane and the L86 V8 with 11.5:1 CR designed for 91 octane.
No GenV engine at this point is designed for E85 FlexFuel.
LV3: 285 hp/305 lb-ft on gas; 297 hp/330 lb-ft on E85
L83: 355 hp/383 lb-ft on gas; 380 hp/416 lb-ft on E85
#52
http://media.gm.com/content/media/us...v6-torque.html
This link doesn't say anything about FlexFuel and doesn't show the numbers you show.
http://media.gm.com/content/media/us...rado/2014.html
Can you provide the link where you found the E85 info?
EDIT: I found the link you were referring to.
http://media.gm.com/content/media/us...2014.tab1.html
My bad on the E85 info.
#53
Sorry, totally spaced on the copy paste action!
http://media.gm.com/content/media/us...2014.tab1.html was the link I was referring to, looks like you found it.
#54
My LS3 has been running on E85 for over 13 months, on a completely factory/stock fuel system. ZERO issues, and I dyno'd 420whp/420tq with ZERO mods other than E85
Results don't lie for the naysayers
#55
13 months, that's a really long time... we should probably re-write what we know about chemistry immediately.
#56
E85 is a wonderful fuel alternative, and it's cheaper than standard gas and you net race fuel results. I recently pulled out my injectors, and checked my spark plugs and they look polished. Car is really happy with E85, and so are my track times.
With a 2.2 sixty foot I ran a 11.97 @ 122 mph. Not bad for a tuned E85 car
#57
Hmmm, a 25hp gain on a 5.3L truck engine? I wonder what a LT1 could do?
#58
At least I have real world data to share
#59
40hp!
Why do we have to keep catching people up on this subject?
