Questions about the new Michelin PSS-ZP
Old 05-07-2013, 07:27 AM
*C7*
*C7*'s Avatar
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default Questions about the new Michelin PSS-ZP
1. Is this the 1st PSS that is ZP?
2. Are all ZP PSS going to be this "new improved" compound?
3. Is the new compound going to be available on the non ZP tires?
I would have thought they would have given the new compound tire a new name to avoid confusion. But then again I may be the only one that is confused.
I sure hope the are much improved over the current PSS at the track.
Old 05-07-2013, 12:44 PM
Gearhead Jim
Support Corvetteforum!
Gearhead Jim's Avatar
Received 2,046 Likes on 1,358 Posts
St. Jude Donor '13
And another question:
Is the "new improved" compound "improved" in a way we will appreciate? Even the Supercar tires on the C6 Z51 had a rolling resistance (MPG) spec they had to meet, and probably a cost target. Requirements like that tend to work against getting the tire most of us would want.
Of course, anything from Michelin seems to be a big improvement over the Goodyears...
Old 05-07-2013, 12:55 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
from what I have read, the PSS used on the Z51 is a different tire than the PSS used on the base C7(in addition to different sizes, 19" vs 20"). The PSS used on the Z51 has a different rubber compound and a different tread pattern, from what I understand.
Thus I suspect that the PSS tires on the C7 are different from the PSS tires now on the market(in addition to the run flat feature).
Old 05-07-2013, 01:00 PM
ZL-1
ZL-1's Avatar
The 18/19 version has "new improved" compound for low rolling resistance, 1G capability, wet traction, and a 300 treadwear rating
The 19/20 version has "new improved" dual compound for outstanding track performance.... LRR and treadwear are not mentioned.
Can anybody tell us why these two totally different tires have the same name?
Old 05-07-2013, 02:10 PM
Gearhead Jim
St. Jude Donor '13
Marketing.
To Questions about the new Michelin PSS-ZP
Quick Reply: Questions about the new Michelin PSS-ZP
