rear axle - auto v manual
Old 04-30-2013, 12:42 PM
schilitj
Support Corvetteforum!
schilitj's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Default rear axle - auto v manual
I'm going to order the Z51 with the auto tranny. Does that change the rear axle ration from 3.43 to 2.73 as a result?
Old 04-30-2013, 12:45 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
Yes. Actually it is 3.42 to 2.73. All manuals get the 3.42. The A6 non-Z51 gets a 2.56 and the A6 Z51 get a 2.73.
Old 04-30-2013, 12:49 PM
schilitj
schilitj's Avatar
Thanks. The rest of the build is:
black on black coupe w/Z51
3LT trim
auto tranny
NPP exhaust
red calipers
black wheels
Magnetic select ride
Old 04-30-2013, 12:50 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Yes, but the automatic transmission's gear ratio's are much lower than the manual's gear ratios, and you will end up with an overall lower gear vs the manual with the 3.42.
Don't get caught up in looking at only the rear axle ratio.
To rear axle - auto v manual
Quick Reply: rear axle - auto v manual
