Is MSRC an essential option?
If you plan to order a lightly optioned Z51 car and plan to track 3-5 days a year, is MSRC an essential option? Is it really needed since the car comes with driver select mode? If you had to pick between the MSRC and competition seats which would you pick?
Received 5,332 Likes
MSCR is a must have for me, more so because of it's real world benefits vs just the added benefit on track day. The ability to have your cake and eat it too make the MSCR equipped Z51 a great street ride/track car.
I believe if you have MSRC, then there are more parameters being manipulated when using different driver select modes; so, yes, MSRC might just be an essential for best usage of the different modes.
I am now envisioning the transformation the driver select mode would do on the (rumored) L88 engine option when one switches into Track mode…!!!
During the Bash, I was convinced that F55 was the optimal suspension package for a C7. Look at the extra area available for damping in the picture. And valve adjustable shocks don't adjust while you are driving. You have to pit the car and tweak the settings. [IMG][/IMG]
The other option I was convinced to buy is the comp seats, to be able to put a harness (or two) in the car. The C7 is going to be a great track car, and you will need the extra margin of safety a five or six point harness will give.
If I had plenty of money, I'd spring for those shocks. 1800 isn't that much compared to how much they used to cost, and from what I've heard the new ones are pretty badass.
They said there are now much bigger differences in each setting etc so you can really tell a difference.
Anyone know how long the MR shocks have been lasting the last few years?
It's a tough decision for me because I don't have the luxury of having the MSRC's and competition seats. I would need to pick one or the other.
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
don't get me wrong, I'm not concerned. but, how are you going to use the Corvette? remember that these options have intended uses, unless you just want options because they are the cool thing to have.
I'm on the fence as well, but money is my biggest problem as i'm trying to make a responsible choice on options. One thing about the MSRC's is that it can be VERY comfortable for daily driving, then VERY stiff and sport-like for track use.... it sounds like a dream. I would much rather have the shocks than the seats.
My LS7 should also be good for 100,000 miles. Ask me why I'm going to spend $5000 for new heads as soon as the factory warranty runs out(and I will have less than 30,000 miles on the LS7 at that time).
You can add a track seat much easier than try to tweak your suspension. I would expect Sparco or another manufacturer will put something together to bolt in to the C7. If I can't get the price point down, the seat is the first option I pitch. But I have two Recaro seats sitting in the attic right now, so all I need is an adapter base. They have a ton of hot laps, but look almost as good as new (except where the roll cage wore a hole in the fabric on the seat back).
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
As far as the $1,995 Competition Sport Seat option, I can't see that it would be worthwhile unless you plan on installing a set of 5-point safety harnesses in your car.
From what I understand, a 5-point system is what these optional seats were made for, and a 5-point harness will not fit in the standard AQ9 "GT" seats found as standard equipment.
Basically, if your not installing a 5-point harness, your wasting your money.
Buy the MSRC's when you get the car. You also get the upgraded traction control with the MSRC option. It's not just rear traction for acceleration. It works on all four wheels to improve your lap times.
Anyway, getting the PTM only with the MR shocks makes it almost a must for me....if I had the money to buy one lol
MSRC is more necessary if not tracking it daily
Heard an interview with an engineer who said that the MSRC made the track mode "slightly stiffer", but made the touring mode "much, much softer". He stated that it made the Z51 the "ultimate no-compromise" car. That changed my mind. Originally was not getting it, but now added it to the Z51.
