Why didn't GM increase the bore spacing on the GEN V Motor?
It seems strange that if GM spend $1,000,000,000+ developing the LT1 that they wouldn't have increased the bore spacing slightly to accomodate a larger displacement motor on the same architecture base (since it really wouldn't cost anymore). Yes, I understand the push for fuel economy, emissions, etc, however, for an all out performance N/A motor it seems this would be easily accomplished via more cubic inches and the fact that this larger displacement derivative motor could find it's home in Trucks, SUV's, Motor homes, large industrial trucks, etc. since forced induction motors typically get less economy.
☠☣☢ Semper Ebrius ☢☣☠
So this thread's question shouldn't actually be "why didn't GM increase the bore spacing on the GEN V motor" but rather "why didn't GM put a big block motor in the C7".
Because its not necessary. Even with the Gen4 motors, the LS9 did everything the LS7 did. And it did it relatively cheaper & more reliably.
Why invest in a 7.0L Gen5 motor, when you can simply supercharge the 6.2L Gen5 LT1 and make tons more power?
Because their existing transfer machining lines were originally built for blocks with 4.4" bore spacing. The Nascar engines do have 4.5" bore spacing but they are not machined by GM, nor are they used in any GM lineup. A race only block/heads to get a larger bore so they can have a shorter stroke(for 9500 RPM) and remain within Nascar's displacement limit. The other manufacturers also supply non production blocks/heads for the Nascar teams.
Increasing the bore spacing would have increased the weight of the engine as the engine would be longer and GM would have had to spent tons of money to purchase new transfer machining lines. A longer engine will also not fit into the box that a smaller engine fits into. That means much of the product line would have to have an enlarged engine compartment to fit the larger engine, thus more hundreds of millions of dollars wasted.
There are one or both of two differences between a "small block" and a "big block". Deck height and/or bore spacing. Added weight occurs with both.
Received 3,787 Likes
"Ask Tadge" Producer
Packaging aside, 4.4" is and has been the de facto standard for all small block Chevies since the 50s. Anything bigger is, by definition, a big block. And unfortunately, according to GM: the big block Chevy is deadski.
jas
If I remember correctly (which I sometimes do not), the LT1 has the same bore spacing as the previous generation LS motors, which in the LS7 provides 427 cu. in. (7.0 L). Chances are, they will not need a motor larger than that for production vehicles, and increasing the bore spacing adds weight and girth to the motor. Remember, the LT1 still is a small block. Sure, a small percentage of people would like to build a 500 cu. in. motor, but the number of people demanding minimal weight probably outnumber the number of people who want a large block motor. Anyway, I assume large blocks are still available in the aftermarket.
Because the Gen V is an LSx engine with tweaks to accommodate DI. It's basically the same engine block. The cylinder heads have an extra bolt on the bottom edge, like the LSX iron block and some aftermarket blocks, but even they look like they would bolt right up to an earlier block. The water pump has the pulley moved, but looking at the bolt pattern on the block, it's the same as any LS motor. There are tweaks to be sure, but this motor is just the next step in the line started with the LS1. Makes sense. You can reuse a ton of parts. Displacement wise, it's able to go plenty big considering the standards the Feds are imposing.
jas
AIR FORCE VETERAN
I did.. I guessed....well no but I thought 283-283 was the ultimate. Then the 327.. It had to be over..nope 350...it amazes me they can build a V8 with two valves, and keep increasing the horsepower and torque. It is a simple air pump with a given displacement amazing.
What makes you think it wouldn't cost any more?
And hey, I am so tired of dicussions about tail lights and why the LT1 isn't rated more than 450HP that I thought we could use a new topic to debate
