Bash updates and info
Old 04-25-2013, 01:24 PM
RC000E
RC000E's Avatar
Default Bash updates and info
Points of interest so far:
Z51 4-5 seconds faster per lap at vir than prior z51 car. This is with c7 equipped with full datalogging equipment. Would not give exact time but it appears to be likely its 2:50 or 2:51
Shakedown test between grand sport oem goodyears vs c7 245/285's yielded 1 second per lap faster time. Test car was c6 z06. Vir. They have been amazed by the michelin tire
C7 now has adjustable rear caster, improved roll center and lower cog than c6
Mero says, the car feels lighter and is an absolute monster to drive....he assures everyone they'll be amazed.
MR suspension vastly improved. Faster processor, dual coil, far better ability to fine tune. The changes between modes for touring and track are substantial and only possible via this new generation system.
There was a lot discussed about E LSD and E power steering. If anyone wants details or has questions...ask.
Stiffness between the steering wheel and wheel bearing hub assembly improved 500% over c6. Communicates much better feel, improves response and reduces dynamic changes under load.
Nurburgring later THIS year
Someone started the vert while the interior guys were talking...good stuff!
Z51 brakes have 30% more swept area than prior z51's...even more swept area than c6z
New rotor design communicates very little thermal load from rotor to hub via new two piece design
More to come. If youre curious about anything, post it and I will try to get an answer.
Old 04-25-2013, 01:26 PM
Stingray23
Stingray23's Avatar
Old 04-25-2013, 01:27 PM
LT1_E85_Corvette
LT1_E85_Corvette's Avatar
Have they talked about the LT1 yet?
RocketGuy3
RocketGuy3's Avatar
Damnit, so still no word on the power output or weight?
Old 04-25-2013, 01:34 PM
Jawnathin
Jawnathin's Avatar
For clarity, they used the OEM 275/325 Goodyears on a C6Z, then switched to the narrower 245/285 Pilot Super Sports on the C6Z, which was then 1 second a lap quicker with the narrower Super Sports around VIR?
Very nice. I know both tires very well (I have PSS on my DD) and I can't say I'm surprised. The PSS is a VERY good tire. I can't wait until they make them in larger sizes for 19/20 setups. I still have my PS2s to burn through first.
Thanks for getting info. Looking forward to more updates.
Old 04-25-2013, 01:39 PM
Boo383
Boo383's Avatar
Old 04-25-2013, 01:42 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
So the comparison had nothing to do with C6 vs C7, but just the differences in the tires.
I wonder if they also put a set of the new Michelins on the Z06, using the Z06 sizes and compared.
Old 04-25-2013, 01:48 PM
Kappa
Kappa's Avatar
Are you glad you went now?
If Tadge didn't sell people on the C7, maybe Mero can. If you don't believe him well...
Old 04-25-2013, 01:54 PM
Jawnathin
Jawnathin's Avatar
Wish they were more specific with the results but that sounds pretty darn quick. Pretty impressive. A bit behind the ZR1 but a hair quicker than a ZL1 using GMs test results.
FWIW, here are some other tests around VIR... those early C&D Lightning drivers (2006-07) must have been really awful or had some really bad weather those days. I take the results with a grain of salt but the data points are interesting.
C&D is also about 5 seconds a lap slower than GM test in both the ZL1 and ZR1...
GM VIR Testing -
ZR1 (Cups) - 2:45.63
ZL1 - 2:52.38
C&D VIR Lightning Lap
ZR1 (Cups) - 2:50.7 (02/2012)
ZR1 (PS2s) - 2:51.8 (02/2010)
Z06 (Z07 PS2s) - 2:53.5 (02/2011)
Camaro ZL1 - 2:57.5 (02/2013)
Z06 - 2:58.2 (08/2007)
GS - 2:58.3 (02/2010)
Z06 - 3:01.1 (11/2006)
Z51 LS3 - 3:01.20 (11/2008)
Camaro 1LE - 3:01.5 (02/2013)
Z51 LS2 - 3:03.6 (08/2007)
Z51 LS2 - 3:09.3 (11/2006)
Old 04-25-2013, 01:58 PM
Magister Ludi
Magister Ludi's Avatar
Thanks very much for the info.
Old 04-25-2013, 02:01 PM
Kappa
Kappa's Avatar
So what are the details on the e-LSD?
Old 04-25-2013, 02:02 PM
Jawnathin
Jawnathin's Avatar
That is how I understood it when 'the test car was C6 Z06'.
I'm sure they tested the larger tires at some point, but they wouldn't dare share the results. It wouldn't make sense to upstage their new model with their outgoing car.
Old 04-25-2013, 02:03 PM
BeaZt
BeaZt's Avatar
St. Jude Donor '14
Thanks for the info
Old 04-25-2013, 02:05 PM
JustinStrife
JustinStrife's Avatar
Old 04-25-2013, 02:09 PM
BWF07
BWF07's Avatar
St. Jude Donor '11
Oldtimer
Thanks for the info, hope the prices are announced today.
Old 04-25-2013, 02:11 PM
BERETTA
Support Corvetteforum!
BERETTA's Avatar
Thanks for the updates
Old 04-25-2013, 02:17 PM
jimmyb
jimmyb's Avatar
Received 4,248 Likes on 2,023 Posts
GM VIR Testing -
ZL1 - 2:52.38
Are the GM times with Jim Mero driving?
Jimmy
To Bash updates and info
Old 04-25-2013, 02:18 PM
ldepalma
ldepalma's Avatar
Keep the info coming, thanks!!
Old 04-25-2013, 02:34 PM
JockItch
JockItch's Avatar
Received 5,299 Likes on 1,972 Posts
Jimmy
I'm pretty sure the ZL1 time was with Camaro engineer Aaron Link. He's the same guy who ran the official GM time on the ring with the ZL1.
Old 04-25-2013, 02:35 PM
MikeyTX
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
IBTL now means
Quick Reply: Bash updates and info
