The Tires!
Old 04-20-2013, 04:05 PM
johnglenntwo
johnglenntwo's Avatar
Default The Tires!
C6 Z51 RR
P285/35ZR19
Run Flat
Treadwear: 220
Traction: AA
Temperature: A220 AA A
1323 lbs
44 psi
9/32"
33 lbs
9.5-11"
10"
11.4"
9.2"
26.9"
775
US
C5 Z06 RR
P295/35ZR18
91YLL
220 AA A
1356 lbs
44 psi
8/32"
28 lbs
10-11.5"
10.5"
11.7"
10.2"
26.1"
801
US
C7 Z51(not ZP's) RR
285/30ZR20
RF
300 AA A
1709 lbs
50 psi
10/32"
27 lbs
9.5-10.5"
10"
11.4"
10.2"
26.8"
777
FR
These tires are bigger and tougher!
Old 04-20-2013, 04:08 PM
SD1
SD1's Avatar
Who is the manufacturer? I want to buy stock. : )
Old 04-20-2013, 04:11 PM
johnglenntwo
C7 Michelin Super Sports
http://www.tirerack.com/tires/tires....ot+Super+Sport
(The ZP's aren't listed yet!?)
C5 Goodyear F1
C6 Goodyear F1 RF
Old 04-20-2013, 04:17 PM
michaelinmech
Support Corvetteforum!
michaelinmech's Avatar
So are those weights comparing 2 ZP tires against 1 non-ZP tire ?
Old 04-20-2013, 07:06 PM
johnglenntwo
Default No!
The C5 Z06 didn't come with ZP. And the same Super Sport tire comes in at 24lb for a Ferrari. A few pounds will have to go on in a ZP, but, the 20" really have small side walls so a really marginal amount. And those side walls should really help tighten up the handling.
What was particularly interesting to me is that these new 285's have the same thread width as the 295 and over 1" more then the old Z51 tires.
Old 04-20-2013, 11:24 PM
TRAKCAR
TRAKCAR's Avatar
SuperSports are great tires, I've tried them at the track and put them on my wife's car and on my street wheels.
They last very long and offer good grip, but not R rated grip like Nittos or Michelins Sportcup tire.
Old 04-20-2013, 11:27 PM
michaelinmech
Though that may or may not hold true for the ZP versions ???
Old 04-21-2013, 09:31 AM
ANTIVNOM
ANTIVNOM's Avatar
Wait, are you saying the C7 with Z51 does NOT come with zero pressure tires? That doesn't seem to jive with the order guide. I would certainly love it if it didn't come with run flats, I detest the things. It's my biggest gripe on my ZR1.
Old 04-21-2013, 11:57 AM
BlueOx
BlueOx's Avatar
I hope I can get a set of these to replace my OEM GYs on my '05.
Old 04-21-2013, 05:49 PM
johnglenntwo
Default Yeah, your right!
The handling should be more precise and quick. And perhaps PTM will be a necessity even for some of the better drivers. That's what it is there for!
Old 04-21-2013, 05:56 PM
johnglenntwo
Another good point in have those small side walls seems to be the thread width is relatively larger. It makes sense, since, the curve doesn't need to be there for support.
Anyway, there should just be a few added pounds.
Old 04-21-2013, 05:59 PM
johnglenntwo
Default Right!
No, they are just being made up from what I understand. But, of course the same sizes are all ready available without just for you!
Old 04-21-2013, 06:10 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
How many laps around Sonic did it take you to wear out the OE Goodyears?
Old 04-22-2013, 04:08 PM
johnglenntwo
Default Should be Groundbreaking!
The MICHELIN Pilot Super Sport ZP tire also features the next-generation of racetrack-born tread compounds found in the record-setting Pilot Sport Cup ZP of the C6 ZR1 and Z06. Unlike the MICHELIN tire fitted to the standard 2014 Corvette Stingray, the Z51 tire features a custom dual-tread compound and pattern that achieves near-racing-slick grip and handling levels, while providing longer tread life and wet handling capabilities.
http://www.reuters.com/article/2013/...60+PRN20130114
State of the Art!
And just like the GTR doesn't have an AWD off mode. PTM and Throttle Blipping can make hauling *** less labor and skill intensive!
Old 04-22-2013, 04:40 PM
ldepalma
ldepalma's Avatar
State of the Art!
Any pics yet of the Z51 tires up close?
Old 04-22-2013, 07:02 PM
johnglenntwo
Default And let us not forget!
Many of the C6.R’s cabin controls and switches—including the car-to-pit radio, windshield wipers, lights, traction control,
Read more: http://www.vetteweb.com/features/vem...#ixzz2REfFWBX3
The race car uses traction control. Skilled in the street cars drivers don't need it with the Cup tires. Therefore deductive logic yields there is a lot to play with in a lesser? Vette.
I'm sticking with the 7:26 on E85!
Old 04-22-2013, 07:49 PM
racebum
racebum's Avatar
boy tires have improved. back in 2001 when we had the 220utqg goodyear supercar. now that tire will be outdone by a 300utqg michelin pss today. a tire that not only performs better, it lasts longer!
and honestly. i think what are considered hard sport tires like the bridgestone 760 {utqg 340} are equal to the old supercar and with better rain performance
tire tech has been advancing at a similar pace to CPU's the past 20 years
To The Tires!
Old 04-22-2013, 09:37 PM
johnglenntwo
Default These are New!
These babies will have more grip too, and are not comparable to anything known now!
Old 04-22-2013, 10:03 PM
Toilets
Toilets's Avatar
The problem is that there are no other varieties of tires for added grip in the z51 sizes. I fully plan on tracking this car like I currently do with my centennial however there is nothing other than the Pirelli corsa which is a 60 wear in these crazy 20x10 rims. If I'm not mistaken, there isn't a slick yet developed for this size? Hoosier nor BFG have them...
New tech or not, a 300 wear is way to hard for a track day car.
Old 04-23-2013, 01:28 PM
johnglenntwo
Default All addressed Already above!
Again the C6R race team uses TC and electronic shifting. Use the C7s electronics and focus on aiming the cars line is the way I understand it. If you want overkill tires and number handling stick with your Centennial for now.
Quick Reply: The Tires!
