Could the V6 TT be true ?
#321
And you accuse me of being the pretzel-bending weasel? LOL.
You are aware that R&T compared the Noble M400 (425 hp, 6.0 lb/hp) against the '06 Z06 (6.2 lb/hp) at the Streets of Willow, right? The Z06 was on the old Goodyear F1s; Noble on Pirelli P Zero Corsa. Tell me which one was faster.
#322
It should also be a matter of principle on a discussion forum to actually answer the very relevant questions posed to you. As you see, it is not I who is diverting. Just answer the question.
Yes, it is unpleasant for you that you cannot answer the questions of all of those other factors I mentioned. Didn't Nissan's GT-R show us that you can make no accurate prediction of performance based on power/wt? Didn't that supercar shootout a few years ago on the 'Ring show us that power/wt didn't determine the fastest car? (The Koenigsegg was the most powerful, with the highest power/wt ratio; the Maserati MC12 was among the least powerful; yet the Maser set the fastest time, while the Koenigsegg was slagged for certain behaviors that don't show up on a spec sheet.)
Uh, and where did I argue against that concept? I even brought in the XJ220 for chrissake. And that's not all you did:
Contrary to your claim that all you were saying is that a V6TT can be super fast (a claim I never disputed and indeed supported by way of a bonafide supercar, XJ220), you went above and beyond that and made repeated claims that the Rossion will easily beat the ZR1. How can that be true, if the same-weight (but +200 hp) M600 on fatter tires can't outrun a 458 with ease (it's actually slower) on the same day, while on the same day, the ZR1 is faster than the 458? By your logic, the Rossion should be faster than the M600.
#323
Nevertheless, I am a great fan of big motors and gas gazzling in the name of performance but these two have to go hand in hand. I already mentioned this before that Tadge is castrating the V8 in the name of corporate interests and he does it in the worst possible way. Gotta pick your battles I guess, if GM wants Corvette to create an illusion of a sportscar with penny pinching and environmental goals, then V8 may not be a viable option anyway.
#326
So basically, all we have to do is find a car that has the same Cd, same weight and a V6 (I guess twin turbo) achieves the same engine power output? Here is a thought, you find out and demonstrate that is worse or better or the same
#327
Well it's to the point. You, as many, assume V8's in performance cars are dead because they presumably are inferior in efficiency (MPG) in accordance with the power they make compared to ttV6's. Not asking for a ton of examples, just one.
HP & EPA C6 vs HP & EPA of... Clear enough for ya?
#328
#330
#332
#333
The EB motors make 420tq at 1500 rpms. There's no reason why GM can't modify a V6 to match a v8 when they were doing it in the 80's.
My Ecoboost f150 gets 19city and 28highway. And that's without me even trying.
#337
M600 was weighed in that test at 2745 lbs. That is only 70 lbs heavier (not 200) than R&T's curb weight of 2675 lbs. We're still talking 4.22 lb/hp for the M600 vs 5.9 lb/hp for the Q1.
Tell me one you think was faster on the track: Noble M400 vs C6Z on GY F1s. Same-day test with pro racing driver Gary Sheehan in each car.
#338
I didn't edit anything other than to omit those passages that are not relevant to our current discussion. I did not switch your words, if that's what you're getting at. I highlighted the point that you now seem to be running away from: Your claim that the Q1 easily beats the ZR1.
http://fastestlaps.com/cars/noble_m600.html
And Noble itself lists the DRY weight as 2641 lbs
http://www.noblecars.com/m600/m600.html
Rossion on the other hand give the DRY weight of Q1 as 2475 lbs. Are you suggesting Q carries around 30 gal of fuel and another 10 gal worth of other fluids to make it run?
http://www.rossioncars.com/model-specs.php
I think you should practice finger math more. Nice try with M400 considering less power and different aerodynamics. M400 is actually lighter though
I think we are done now, I hope.
#339
That's called not following the herd down the "el cheapo" road. There is no point in a turbo V6. It's a downgrade.
Rear wheel drive was considered a 1970s mentality in the 1980s. I don't think we want to go down that road either.
Michael
#340
That's not 1970's mentality. I guess Ferrari, Lamborghini, Maserati, BMW, Mercedes, Lexus, and every other manufacturer with V8 and V12 engines has a 1970's mentality by your measurement.
Rear wheel drive was considered a 1970s mentality in the 1980s, too. I don't think we want to go down that road either.
Michael
Michael
