Same Old Fit, Finish and Build Quality?
cheap harmonic balancers
rear ends requiring brand new clutch packs
faulty water pumps
427s with "dropping valves"
Flying "roof tops"
But being on other forums of the so-called "premium supercars," man, those guys have some issues too. Imagine spending over $225K for a Lambo that you can't park on a hill with "E-Gear," or a $160K Porsche with a faulty shaft or a 458 that goes up in flames? Yes, it could be worse.
If these sort of things worry you, then you can always settle for a "passenger vehicle."
Jimmy
My 05 C6 is put together a 1000 times better than my 03 350Z, both first year production cars.
The only gripe I have with the C6 relative to the 350 is steering feel. Besides steering, the C6 exceeds it.
AIR FORCE VETERAN
I'm not too concerned with "fit and finish" but it does seem like GM would want their two "show" cars to be the best two cars they make to show off to the world,not the other way around. Test mules a different story but the two cars that have been at the auto shows are not mules they are show cars
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
This ....... And I go back to the beginning with my late fathers two C1's. My C2, C4 and, several C6's.
I have a Mil Yellow '01 that is as good in fit and finish as any other car that I have ever seen. The '07 should be better in that they have built in methods of aligning components.
Funny thing is, I FIT just fine in my Vette, and every time I FINISH a drive in it I emerge with a huge grin. So, I certainly got the fit and finish I expected.
Seriously, though, I think if your car is used as a DD, and becomes a 10-footer after a few years, the minor panel gap and orange-peel issues don't matter as much. Key word is "minor," which is how I would describe the C6 and where I'd bet the average C7 will fall.
My '10 C6 is one of the best cars I've ever owned. Fit & finish just as good as my RX-8 and MazdaSpeed6 that were built in Japan. Anyone know of any 2 seat sports cars, with this much performance, in the $45-50K price range, that have better fit & finish?
Supposedly they spent a lot of time on this for the C7 to correct it. I hope they did so C&D can stop using it as a point deduction in the comparison tests.
I guess some of you folks have had fit/finish issues with your C6s. I have two and there are no fit/finish issues with either of mine except for a minor issue with the stripe on the 427.
I believe that the "fitment" issue in the photo is a matter of angular perspective rather than a bad gap issue. A perpendicular view would tell the tale.....
#33
AIR FORCE VETERAN
I think you could find fly sh*t in pepper.. IMO you call them show cars but only because they show them, they are still Mules. Other people complain they can not get close enough..Doesn't matter they are still not production cars. I relate that to a beautiful woman. Why spend your time looking for flaws?
#35
The C-7 I saw at the Barrett Jackson looked great and certainly the paint job was way better than the factory paint. The car looked show quality, BTW Im changing my opinion on the roof line it's starting to look better to me than when I first saw it.
#36
#37
#39
I paid 39k for my 2012 1LT. Harmonic balancer failed at 30 miles...good got that out of the way for awhile. Spent 4 hours aligning panels mostly rear hatch and hood. Have door to window trim coming loose and one corner of the front bumper at the head lights does not fit right.
Basically I got exactly what I expected. None of it bothers me at all. This is GM folks. They could not get a column lock right ever and even screwed up the bypass harnesses on the C5. Could not get a HB right on the C6 so who knows what they will never get right on the C7. And paint and body panel fit are what they are. It can all be adjusted and corrected.
I still love the car. It is what it is.
#40
I find few flaws in my 2013, the build quality is actually very high. In BG watching C6's being built last year, there was much focus being shown to fit, finish & build quality, and specifically preventing inconsistent gaps like you show in the pre-production car. While they will wrestle with some issues learning to build the C7, I would expect high quality like my 2013 from production C7s fairly quickly.
Cheers,
JB
Cheers,
JB
